Another ABS question
Doom dee doooooom
Ok so now I have a new ABS question. ABS light came on. I think damn it i just fixed this. Check everything, the tank on the ABS pump is bonne dry. Fill it up, lasts maybe an hour and is empty. I didnt see any OBVIOUS oh my god leaks anywhere... is this a common thing? I am starting to get PISSED at this stupid abs system. Alrighty thanks.
ryan
ryan
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
I have had nothing but problems with my ABS system as well, the light continues to come on as well. But your problem sounds pretty bad, when you start your car, does your abs pump groan and overrun for a while, you will be able to hear and feel it.
Doom dee doooooom
yup it does the groaning thing and then it turns off after 30 seconds and the ABS light comes on. It doesnt do it when I fill up the resivoir, but the resivoir empties shortly and then it does it all over again. Any ideas?
Ryan
Ryan
I have the same problem, and somehow i got a acura service bulletin from June 29,1998 number 97-002.
Don't know how i got ahold of it, can't find a link to it online..
Brake fluid Leak from ABS modulator.
Symptom
Brake fluid is dripping from the left front corner of the car, and the ABS modulator is wet. If the resivoir is emty, the ABS light may also be on, and a Code 1 stored.
Corrective action
Remove, reinstall, and torque the plugs in the ABS modulator assembly.
Note: Use the 1997 2.2cl service manual for reference whem performing this procedure
Required materials
Brake assembly fluidL P/N 08798-9019
Sound like you?
Looks like i have a couple pages of the service manual too. No idea when i got this, I still havn't gotten to fixing the problem myself. I'll scan it as soon as i get my windows pc back.
Symptom
Corrective action
Required materials
Sound like you?
navtool.com
31
11-16-2015 08:30 PM
lanechanger
10-13-2015 10:56 AM
navtool.com
09-25-2015 05:15 PM
