Advancing the Timing
100% Dominicano
3.0 V6 owners help me out
1. The usual technique of moving the distributor to advance timing is not applicable to our cars because our distributor is permanently situated, is this correct?
2. Can we get an aftermarket distributor that you will be able to move? If so which one?
3. I heard that one of the guys on V6performance.net, who dynoed at 211 whp NA physically cracked open the casing and had his mechanics advance the timing. What do you guys think of this? Does it sound like it would work right?
4. MSD makes a timing controller that is supposed to let you retard or advance the timing. Their website says that it works with almost any car that has a distributor. Do you guys have any opinions of this?
Trailblazer = SUCK
you have to short out the service connector while you do it otherwise it will automaticly correct it. Its the same connector that you use to make the CEL throw codes. Not sure for a 3.0 though...
Originally Posted by Motohip
can we do it on the 2.3's?
no
and unless ur runnin nitrous i wouldnt advance the timing anyways. im sure u can do it thru the v-fac.
Trailblazer = SUCK
you cant do it through the vafc. only a hondata system is capable of that or those shitty ebay "spoon chips". there is no need to advance it anyway. honda set it where it was for a reason. like wilp said, unless you are spraying or doing heavy boosting there is no need to change it.
NAWWWWSSSSSS
1 Post
Trailblazer = SUCK
Originally Posted by shineynitelite
if your going to spray you will blow your shit with advanced timing.. if anything you want to retard it..
1 Post
I'm a llama :(
Most Honda's don't run rich or they wouldn't have the LEV and ULEV status.
Why can't I advance timing on the 2.3? I did it with my del Sol...all I needed after that was to run 92 octane.
1 Post
well, not extremely rich, but a little richer than necesary. Thats why the VAFC actually does any good. It needs alittle adjustment here and htere. I'm sure you could get 5-10 more hp across the whole rpm range with little adjustments in timing.
Always drivin 100+
Originally Posted by Zerostatic
That's gay, there has to be some way around that.
I'm a llama :(
I don't think it will retard the timing unless it senses some sort of knock, which won't be present if you run higher octane. It worked for my other Honda, why not this one.
100% Dominicano
Guys, it's commonly known that advancing your timing results in more power (you just gotta use a higher octane). Obvously there's room for some advancement cuz Honda meant for us to use the lowest octance possible AND they have to cover their asses (and their reliablility rep) by playing it safe.
If there was any way to accurately advance the timing w/o it correcting itself, I'm positive that there would be some good gains.
1 Post
do the 3.0's even have a knock sensor? I was reading a post in the second gen forum by scalbert that seemed to imply that they didn't. kinda confused now.
So if we were to replace our ignition system with an MSD ignition kit we could advance the timing? Or would th eonly way be to make the engine think it's always getting cold air ike the "speed chips" they sell on ebay, lol.
Trailblazer = SUCK
the only thing advancing your timing on a stock car will do is make the engine burn out faster. the hp increase is so small its definately not worth it.
spoiler900
5G TLX Photograph Gallery
09-11-2015 09:39 PM
