ABS Help - Different
Ok I was driving home today and my ABS light turned on. In the past it was a sign of alternator problems but it doesnt seem to be the case this time. I am only powering a small 4 channel amp right now and with my pumped up alternator i wouldnt think that would cause a problem.... ANY IDEAS OR HELP!?!
ok the ABS light is for diagnosing problems within the Antilock Braking System(ABS) If it were an alternator problem, you would get a Check engine light or possibly the battery light. Its a very good chance that you suffer from the same problem a lot of cl owners have faced: bad ABS module. something in it goes bad and causes the pump(which is the mooing cow sound heard when the car starts up) to overrun. Once this happens, the system is disables and the ABS light will illuminate. If you want to find out what the exact problem is, use the instructions on niedejb's site for further help.
Jamus22
06-11-2023 11:08 AM
mada51589
05-03-2022 09:54 PM
