99 cl 3.0 overheating
Old 08-25-2014 | 12:00 AM
Dukaga33's Avatar
i replaced the tstat and switchs the driver side fan is bad new one in the mail. when i drive around its stays at half when i idle its gos to 3/4-H any ideas well help alot.
Old 09-15-2014 | 04:49 AM
Dukaga33's Avatar
turns out i have a blow head gasket shop wants 1600 to fix
Old 09-16-2014 | 01:07 AM
AnErin's Avatar
6th Gear
There are a couple videos on youtube explaining how to replace a timing belt on the 3.0
DOHC engines have timing belts and is probably the most involved part of that job, resetting the timing. Course if you get that far into it, might as well throw on a new belt.
What other symptoms do you have? If it is ONLY overheating, it may be something else. Normally a bad head gasket creates a list of problems.
Old 09-16-2014 | 06:14 PM
Halmiles's Avatar
8th Gear
How many miles since the water pump was replaced?
Hal
Old 09-17-2014 | 11:38 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Overheating is usually a stuck thermostat
Frathora
09-28-2015 11:29 PM
NSolace
09-03-2015 08:14 PM
NSolace
09-03-2015 08:02 PM
Mikehxbx
08-31-2015 10:17 PM
onedayzpay
04-01-2002 11:49 PM
Quick Reply: 99 cl 3.0 overheating
