6.5 Pioneer PROBLEMSSS HELP!!!!!
Rollin to GT in da CL
Hey
im guessin taht maybe the magnet on the speakers is hitting the door and thats why they are all shuttting off? If thats not it anybody got an idea why when i crank them they all shut off?
If its the size of the speakers then how do i make a spacer or something???
Thanks alot,
A fellow Cler in need
John
Thanks alot,
John
Still trolling
Can you specify if all the speakers in the system shut off, or just the door speakers you installed?
Did this ever occur prior to the door speaker install?
Magnet won't cause it to stop. If the + and - connectors short out due to hitting something, that will do it. But given you say it happens when it's cracked, either an amp is cutting off due to excessive amprage draw, or the speaker's voice coil is shorting out at extension/compression (or the small wire going from the cone to the terminals on the basket).
Try disconnecting the door speakers and see what happens, then reconnect one at a time to see which is the problem.
im back biaaatch!
Hey ma nsorry if this is off topic but i've been trying to get ahold of you for a while...wheres my money for the amp? you said you were gonna send it, so whats the deal?
Brian
Brian
Still trolling
Originally posted by JD22CL
ALL speakers short out???
Ive only replaced the front 2...i think i did something totally wrong
John
John
SPEAKERS REPLACED WITH 220WATT 3-way PIONEER 6x9s and 2-way 180watt PIONEER 6 1/2s
polish_pat
09-25-2015 12:24 PM
Eggs999bacon
09-24-2015 10:08 AM
