5th GEN Accord and 1st Gen CL????
Are they Identical, besides the obvious??? Im thinking about doing an auto to manuel swap.... is everything identical to the 5th gen accords?? If it is does that mean I can use all the pedals from the 5th gen?? Some 5th gen accord people also said that they used preludes parts for their conversions. Is this true?
Turn Signals are good!
a prelude tranny will fit, but probably a waste because of its gearing... a stock cl motor wouldnt do too well with that tranny.
An accord tranny will fit... pedals will fit... all that stuff is the same... and im pretty sure you'll have to change the ecu too... but thats just a matter of a couple bolts and plugs. Its a cable shifter, so that just bolts to the floor in the car and the cables run through the holes already there. There is already a hole for the clutch pedal and master cylinder, its just blocked off by a bolted on steel plate. Theres probably some wirring differences...
It will all fit, its just a matter of some work.
Old Timer
Originally posted by bACURAs
hey d98clturbo, where'd you get your turbo and how much did it cost you. Was it formatted for an Accord or for the CL?
it is hard to say how much i paid because i got alot of ish done...and i also bought an engine management system...so you can say i spent a shit load of $$$$$..
my kit had to be custom made ..i have the h22 in my car..
there is another guy that turboed his CL withthe stock motor...he is making some good power
SidhuSaaB
05-30-2020 12:40 AM
emailnatec
29
09-28-2018 04:27 PM
GWEEDOspeedo
01-15-2016 10:39 PM
