5 speed swap
5 speed swap
yes i searched and i found next to nothing. people r always puttin down the idea or saying "just put in a h22." i know it will require a lot of work but im definitely willing. i made a list of things ill need to rip out of a 2.2CL that i found =P please feel free to add or eliminate anything from it. i know someone out there is more knowledgable than me, this is just a list i made from research.
-5 speed transmission
-5 speed ECU
-Brake & clutch pedals
-3 clutch lines
-Flywheel & Clutch assembly
-Clutch resivoir (master, slave)
-drivers side axel (not sure about this one)
-shifter assembly and shifter lines
-5 speed transmission motor mount
im not sure if im doing it myself cuz i found a shop thatll do it for around $500 (i know em) but i would definitely like to do it for experience but then ill need to buy/rent an engine hoist. im mainly posting this to see if theres anything more, or less, that i need. if your going to say "get an h22" or "dont bother doing this" then please keep it to yourself. thanks -jon
-5 speed ECU
-3 clutch lines
ahnyoung!
-5 speed ECU
-3 clutch lines
-5 speed ECU
-3 clutch lines
i think thats all you need =)
just take whatever the 2.2 manual one came with!?
i don't think it would be that difficult aither!
GOOD LUCK MAN!! more posts and DIY! photo's
Originally Posted by starboy2nv
Good luck and remember to reinforce the firewall, where the clutch pedal goes! my first cL was auto then i did the whole swap to manual and ran into problems with the clutch pedal, but i eventually got it rite!
ex 6 Speed owner :(
I did this swap in my Accord and it was pretty straight forward. Make sure the clutch pedal bracket is in good shape, especially if you are going to run an aftermarket clutch (stronger). My bracket broke the other day which put my car out of commission for a while. You will have to do a little wiring to get the cruise control to work again and overcome the starter lock solenoid. Other than that totally worth it... faster, better mileage, much more fun! Good luck!
its not in jersey, its in PA, about 4 hours away from me. in jersey i got quotes between 1500 and 2000. its a small shop in a small town =) its called Hybrid Dynamics
One custom CL
I have a guy in NY which could do it for $1200 labor. Top quality work. I've done it. There is no 5 speed ECU.
You need tranny, slave and master cylinders, flywheel, clutch, shifter, shifter cables(2), axles, intermediate shaft, clutch pedal (no brake necessary) and $1200 for labor. Let me know if you are interested in getting this done in NY. I had my car converted 4 months ago. Works like a charm.
One custom CL
you can modify the brake pedal they can cut it down for you
as far as axles i got cl/accord 5speed axles plus intermediate shaft I believe you can use one of your old axles but I highly doubt anyone will sell you one axle unless the shop can make one
Originally Posted by NuMnUtZzZ
hey ninety, how much did u end up spending for all your parts alone?
mlody
12-04-2019 02:11 PM
joflewbyu2
10-08-2015 11:16 AM
xsilverhawkx
09-28-2015 06:51 PM
