178k and i think i need to do some maintinance
I need to change timming belt and water pump i think i did back at 125k but i think i should do it again. car is running fine though sometimes at a stop it gets a vibration. anything else i should do. it did have plugs and wires change 6 months ago.
bone stock BTW never got around to my pipe dreams
if you replaced your water pump and timing belt at 125K miles there shouldnt be any reason you would need to replace them at this time. Your supposed to change those every 100K miles. As for the clutch look into exedy or act
EGR valve carbon buildup will cause a rough idle.
Bad oxygen sensors will cause a rough idle and bad gas mileage.
Also clean all the sensors in the air intake path
DeathMetal
08-17-2020 06:30 PM
