120k Mile Tune Up
Ballin' on a budget
120k Mile Tune Up
I bought my CL in December, and so just for shits and giggles I called the dealer to get an estimate on a tune up (Specifically tranny drain and fill) and they wanted $550 to do the following:
Anything else that I need to take care of?
tl;dr what do i need for 120k mile tune up?
- Transmission drain and fill
- oil change
- new wipers
- engine filter replacement
- "inspection"
Skuuuurrrrrt!
Psh, Get it done for free. https://acurazine.com/forums/ramblings-12/acura-mdx-die-cast-194918/
Shits and giggles!!
Haven't heard that in a while.
Shits and giggles!!
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Car is Back
I actually need the same service even though im at 135 k so i need that soon also.
but anyway I got this from the dealer:
A service:
replace engine oil and filter
check fluid levels & conditions of fluids. Top-off as needed.
Perform visual inspection for fluids leakage
Adjust tire pressure to specifications (include spare)
Load test battery
Perform 21 point Inspection
B Service:
INspect front & rear brake clipers, rotors, pads & mounting hardware
Record usable brake lining Front ___ mm Rear___ mm
Record usable tire tread above wear indicators
Lf ___ mm RF __ mm LR ___ mm LR __ MM
Rotate tires
Inspect tie rod ends, steering gear box & boots. check rack grease & steering linkage
Inspect suspension components.
Inspect driveshaft boots
Inspect valve clearences (only if noisey)
Add windshield washer solvent
Add fuel system cleaner to fuel
Reset maintenance reminder
Service C:
Replace air cleaner elments
Check parking brake adjustment
Lube all door hinges, locks and latches
Inspect brake hoses and lines (Inc. ABS)
Check all fluid levels, condition of fluids & check for leaks
Inspect cooling system hoses and connections
Inspect exhaust system
Inspect fluel lines and connections
Check all lights
Inspect underbody
Service D:
Inspect value clearance (2.2 only)
Inspect and adjust drivebelts
Replace transmission fluid
(transmission fluid exhange with conditioner)
Service E:
Replace engine coolant (perform fast flush and add conditioner)
Replace brake fluid (perform brake fluid exhange)
I also got a quote from the dealer which was $805
J.r.
A service:
Load test battery
B Service:
Rotate tires
Service C:
Check all lights
Inspect underbody
Service D:
Service E:
J.r.
mada51589
05-03-2022 08:54 PM
