Windows won’t work
Old 07-07-2018, 09:58 PM
4th Gear
Bfrost's Avatar
Windows won’t work
08 mdx windows won’t roll up or down from any switch s. Will roll down with the key fob though and back up with the key in the door. Any help?
Old 07-13-2018, 09:55 AM
yessir_yan's Avatar
Same thing for me with my 09... Check for a yellow wire that it seems too short and broke. It's located in the connector of your driver's door, when you open the door (near the hinges)
Old 07-13-2018, 03:00 PM
4th Gear
Bfrost's Avatar
Windows won’t work
Thanks for the reply. Ended up replacing the whole harness. More than one wire was broken. It was definitely time. Fairly easy switch out.
Old 07-15-2018, 06:15 PM
typesh22's Avatar
Hi all,
new member here, one question, when you replaced the sub harness did you disconnect the battery?
Old 07-16-2018, 12:51 AM
4th Gear
Bfrost's Avatar
Windows won’t work
I didn’t disconnect the battery. Probably should have working around the fuse box. But I didn’t need any metal tools to do the exchange. And of course didn’t have to reprogram the stereo.
sinistah89
5G TLX Photograph Gallery
07-02-2016 01:56 PM
mrsteve
Technology
20
04-04-2006 04:10 AM
Jawo
07-17-2002 06:53 PM
Quick Reply: Windows won’t work
