Whistling Noise as RPM goes up
I have a 08 MDX. A couple of days ago, it started making a whistling noise when the engine idles and it get more acute as the rpm goes up either by revving the engine up parked or running. Also while running at certain rpm (vibration frequency I guess) I hear a noise similar to when a muffler heat shield is loose and rattles. My suspicion is either exhaust or intake as the noise sounds like air passing through a very small passage (leak). I am almost disregarding an intake leak (vacuum hose or anything similar) since my RPM is stable.
Do you guys thinks this might be an exhaust leak? How do I check this is the case?
As per the rattle, I checked both muffler heat shield and they are good. Maybe another heat shield?
Here is a video with the noise it's making:
maybe a belt tensioner or alternator. Mine did a similar noise and alternator went out a week later....
RL09 (07-03-2019)
Da ham!
Eastern Canada
04-25-2013 08:09 AM
sangamon
08-04-2005 08:52 AM
