Wheel offset
Old 05-18-2017, 01:28 PM
dceclipse's Avatar
Wheel offset
I have a 2011 MDX and I want to put a stock 2017 20" berlina wheels, my question is if the 55mm offset of the 20" wheel will clear or there will be no issue on my 2011 mdx? I know we ran 45mm offset in our X. Thanks
Old 05-19-2017, 01:30 PM
dceclipse's Avatar
Anyone?
Old 05-19-2017, 09:09 PM
Carpayment4life's Avatar
Have you looked at the inside of one of your 2011 rims, for its numbers?
Another option is to go to tirerack dot com, select replacement rims then see if they fit the car that you mentioned "Berlina"
Old 05-25-2017, 06:45 PM
7th Gear
ChitownMDX's Avatar
need to know wheel width too.
Old 05-25-2017, 06:54 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
The OEM Berlina wheels are
20x8 +55
2011 wheels are
18x8 +45
19x8.5 +45
Old 05-25-2017, 07:00 PM
Skirmich's Avatar
I don´t think there will be a problem: https://www.wheel-size.com/calc/?wheel1=255-55-18X8ET45&wheel2=245-50-20X8ET55&fcl=50mm&wcl=30mm&scl=50mm&sr=0mm
Although Scrub Radius will be affected... Seems it needs a 43 offset to be same as OEM, Perhaps a wheel spacer?
Old 06-30-2017, 09:36 PM
dceclipse's Avatar
thanks for all the reply! ive decided to paint my stock wheels, of course by a wheel shop.
