Wheel chart
6th Gear
Wheel chart
I need a new set of wheels for my 2009 MDX, does anyone know if the wheels from a 2018 MDX will fit? It has the same bolt pattern but the offset is different.
Thank you,!
Thank you,!
6th Gear
Mine has an offset of 45, the ones I want to buy have an offset of 55, which I believe puts the rim and tire 10mm closer to brakes and suspension. If I bought a 5mm wheel spacer, I think it will work? Any thoughts? Need to buy asap
thanks!!
thanks!!
Sorry just reread my previous post, wrote the opposite... you are correct, but you need to take into account the width is the wheel as well. If it is a more positive offset and wider wheel then you would need a larger spacer to clear the strut.
~HondaF1~
Check it:
https://www.wheel-size.com/size/acura/mdx/2009/
While some are not exact science - it's a great tool....
