Wheel chart
Old 12-09-2018, 06:23 PM
6th Gear
theocon's Avatar
Wheel chart
I need a new set of wheels for my 2009 MDX, does anyone know if the wheels from a 2018 MDX will fit? It has the same bolt pattern but the offset is different.
Thank you,!
Old 12-17-2018, 03:42 PM
boostedx's Avatar
Is the offset + or - from stock? if + they shoud fit fine
Old 01-17-2019, 09:11 PM
6th Gear
theocon's Avatar
Mine has an offset of 45, the ones I want to buy have an offset of 55, which I believe puts the rim and tire 10mm closer to brakes and suspension. If I bought a 5mm wheel spacer, I think it will work? Any thoughts? Need to buy asap
thanks!!
Old 01-17-2019, 10:16 PM
boostedx's Avatar
Sorry just reread my previous post, wrote the opposite... you are correct, but you need to take into account the width is the wheel as well. If it is a more positive offset and wider wheel then you would need a larger spacer to clear the strut.
Old 01-18-2019, 08:43 AM
~HondaF1~
R J Poseidon 6's Avatar
Check it:
https://www.wheel-size.com/size/acura/mdx/2009/
While some are not exact science - it's a great tool....
bluecarbonfiber
1G RDX Tires, Wheels & Suspension
14
05-27-2017 05:44 PM
Quick Reply: Wheel chart
