what is difference between acura and honda rear differential fluid
Old 04-21-2017, 02:26 PM
jujufly's Avatar
Honda is sell rear differential fluid 08200-9007 is Dual Pump Fluid II, Acura is selling 08200-9007A is DPSF, are they the same? i am very close to Honda dealer and don't want to go to acura dealer to buy it. can I just buy Dual pump fluid for my 2011 MDX car? thank you.
Old 04-21-2017, 02:31 PM
jujufly's Avatar
Previous has mess code, recopy,
I'm a technician at a Honda dealership, and I have a 2nd Generation MDX also, I have bought the thing right before I have started there. I wanted to change the fluids as soon as I could, knowing that it be a fresh start. So I asked my assistant parts manager if he can order a couple quart of the latest ACURA SH-AWD rear differential fluid (DPSF) and I gave him the part number. He said from his mouth "we have the same fluid that we use for Hondas except it doesn't have that "A" at the end of the part number, typically the "A" at the end stands for Acura, and said Honda DUAL PUMP II FLUID should be the same thing. For a second opinion just to make sure, I called the local Acura dealership and ask them can DUAL PUMP II FLUID be used in the rear diff. and they said yes! I been changing the Trans Fluid and Rear Diff. Fluid at every oil change because I have so much left overs from up selling preventative maintenance fluid change services. Makes me feels better because new fluid=less contaminates=less friction clutch material on magnet.
Old 11-19-2021, 04:57 AM
fabioel99's Avatar
Have you had any issues?
Old 12-12-2021, 05:45 PM
NSXTECH
KTIGERT164's Avatar
Same fluid diff name we use both at honda and acura
Old 12-22-2021, 02:54 AM
fabioel99's Avatar
You know here in Argentina the dealerships use ATF DW-1 as a replacement for ATF Z-1 in the REAR diff (in the back of the bottle it says to not use it there haha). We don't have Acura dealerships here (or parts). I complained and they say these instructions come from Honda Argentina. It's crazy. Next change I'll do it myself and use 8200-9007 Dual Pump Fluid II. Thanks guys
Old 12-22-2021, 09:15 AM
NSXTECH
KTIGERT164's Avatar
Those years if i remember came factory fill with atf and also says atf on rear diff by fill plug
binshan
3G RDX (2019+)
04-06-2021 12:55 AM
bruceroush
11-16-2020 07:19 PM
alfadoctor
07-10-2016 05:00 PM
dre707
12-01-2014 07:05 PM
Braz60
08-03-2012 01:34 PM
Quick Reply: what is difference between acura and honda rear differential fluid
