Rear a/c
Old 10-16-2017, 11:42 AM
3rd Gear
Jeff Flowers's Avatar
Rear a/c
I have a 2008 Mdx and the rear a/c blows hot while the front blow cold...i have added air made front colder but no change to back... can anyone assist was told something about HVAC but not sure where to find it in vehicle.
Old 10-16-2017, 03:38 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
I would check the rear air mix motor (That little motor moves a vent so you get either hot or cold air)..
Old 10-16-2017, 08:34 PM
3rd Gear
Sounds right do u know where i would find on the 08 in dash or in middle consult i cant find anything on this model ? Thanks by the way!
Old 10-17-2017, 12:07 AM
Skirmich's Avatar
The Rear A/C has its own unit on the center console (Below the center glove box).
The rear air mix motor should be on the drivers side of the center console: https://www.hondapartsunlimited.com/...dXRvbWF0aWM%3D
You can use the (HFL UNIT) Disconnect video on youtube to see if you can access the Air Mix Motor without having to remove the entire center console (Which is a royal PITA).
And your welcome! Hopefully it can help you fix the issue.
Old 10-17-2017, 12:11 AM
Skirmich's Avatar
This video can help you to learn how to remove the rear center console face:
If possible see if the Air Mix motor is accesible once the rear center console face is removed.
Old 10-17-2017, 01:07 PM
3rd Gear
Ok i didnt see it but didnt know what i was looking for then so ill look again thanks again
