MDX Ignition Cylinder Won't Turn
Old 10-04-2017, 03:24 PM
3rd Gear
CGent's Avatar
I have a 2001 MDX. The ignition cylinder won't turn past the lock position. I'm trying to replace just the cylinder, but can't get it to release & slide out. I need suggestions asap!
Thanks in advance!
Old 10-04-2017, 03:26 PM
Received 8,585 Likes on 6,631 Posts
Have you tried shimmying the steering wheel while trying to remove the key.
Old 10-04-2017, 03:30 PM
ttribe's Avatar
Received 5,885 Likes on 2,900 Posts
MODERATOR NOTE: Thread moved to model-specific forum.
Old 10-04-2017, 03:59 PM
3rd Gear
CGent's Avatar
Yes. There's no problem with the key going in or out. I've had a new key cut & tried every trick to get it to turn. I'm trying to remove the cylinder but the release button won't depress because the key won't turn to the 1 or 2 position.
Old 10-04-2017, 04:07 PM
Ahh, apologies, when i read "slide out" I read it as you couldn't remove your key from the ignition completely.
Old 10-04-2017, 04:40 PM
3rd Gear
CGent's Avatar
Thanks anyway.
Any ideas on the release button???
