2013 Acura MDX, electronic problem.
Hello
I have a 2013 Acura MDX that suddenly stop working the driver for controls. I can't lock or open any doors from the driver for control. Lights are pit and I have noticed that when I lock my SUV with ant of the keys, I don't hear the beep and neither I can't open the rear door. Also, the panic key does not work. I don't know if both issues are related.
First, i noticed that i have to close the for to make those locks keys work, the lights were working properly and them started failing, then i have to open the door just a but to work and now neither with for openor close i can't lock or open the doors from driver side, neither thru are lit.
What should I do? Please advise me.
Regards.
Regards.
Opening and closing the door will change the preasure on the wires between the door and the chassis. You probably have a bad cable harness and will need to take the door panel off to look at it.
It is easy to change and the is a DIY on this site, by Skirmich.
door harness install
It's a $25 part and very easy to replace.
Here's a detailed video on how to do it:
Most of these issues are usually caused by loose wires in the driver door harness. You can diagnose it by looking at the wires, wiggling them a little and seeing if any one of them is loose.
https://youtu.be/aZRB1A1aIpY
Hello
Regards.
Regards.
Spoiler
xgliu128
3G MDX (2014-2020)
01-14-2015 05:39 AM
