Notices
Hard to read OIL on stick
Old 04-15-2018, 01:12 PM
Registered Member
SilverJ's Avatar
Liked 119 Times in 85 Posts
I have a 2011 MDX(my wifes) and the low oil message came on the NAV system. So I went to check the oil. I tried checking it after sitting overnight AND after driving it up and down the block and letting it sit for 5-10 minutes.
I pull the oil stick out, wipe it off, put it back in. Its not clean at all and hard to get a true reading. See attached pic. I dont want to overfill it with oil by accident. I cant tell if this truck has too much oil or not enough. Any assistance would be appreciated.
Oil all over stick...
SilverJ is offline
Old 04-15-2018, 01:20 PM
Registered Member
Pair of TLs's Avatar
Liked 36 Times in 34 Posts
What was the reading when you left it overnight? Does your manual say to warm it up before checking the level? Looks low to me...
Pair of TLs is offline
Old 04-15-2018, 06:22 PM
Registered Member
SilverJ's Avatar
It was the same reading overnight as it was warmed up. Basically hard to read either way.
SilverJ is offline
Old 04-16-2018, 12:10 AM
Registered Member
Jiffy Lube
Stop in one and have them show you.
Old 04-16-2018, 05:50 AM
Registered Member
Liked 39 Times in 34 Posts
Photo didn't work.
Use a paper towel.
Place the edge (last 2") of the oil stick against the paper towel and let the oil soak in.
Remove the oil stick, to see how long the oil residue mark is.
If no oil residue add 1/2 quart of oil and recheck,
Keep adding 1/2 quart at a time, until the oil residue mark is half way, between the stick's marks (holes).
Carpayment4life is offline
Old 04-16-2018, 06:17 AM
mrgold35
mrgold35's Avatar
Liked 564 Times in 472 Posts
How long since your last oil change? You might have to check every 500-1000 miles to get a feel of how much oil you are burning per change. I'm usually about 1 quart per oil change; but, only top off about 1/2 -2/3 the way through my 7500-8500 interval to keep my needed oil level 1/2 quart at most.
I find my oil level can vary if there is a slight incline, decline, or tilt of my 11 MDX. I can only check in my level garage for the correct level compared to my driveway with a decline and slight tilt.
mrgold35 is offline
Old 04-16-2018, 07:26 AM
Registered Member
SilverJ's Avatar
Not sure what your trying to say here. Typo ?
SilverJ is offline
Old 04-16-2018, 07:31 AM
Registered Member
SilverJ's Avatar
Most definitely needs an oil change. It's at 5%. I have a TL as well and my oil reads normal (in the gridlines) and the oil is not anywhere but the bottom of the stick. The MDX oil is all over the stick, which is what I find confusing.
But no matter, I think I will just add oil to it and then get an oil change.
SilverJ is offline
Old 04-16-2018, 11:27 AM
Registered Member
Liked 4 Times in 4 Posts
Because the dip stick has a soft material I believe you are seeing oil resedue from the dip stick touching the interior of the tube on the way down in to the engine... the first gen dip stick was rigid and did not do this.
Illustro is offline
Old 04-16-2018, 04:24 PM
Registered Member
mrgold, have you seen any posts, on how to do a "piston soak" to an MDX?
The goal would be to loosen and flush away ant carbon build up, within the center ring's gap.
In turn, that center oil control ring could expand, to form a better contact, against the cylinder wall and reduce oil consumption.
Old 04-16-2018, 06:23 PM
mrgold35
mrgold35's Avatar
I haven't heard of this fix for the MDX oil consumption issue. My oil usage isn't as bad as other. I can pretty much only have to add 1 quart per 14,000-16,000 miles if I keep the level no lower than 1/2 way on the dipstick level (oil is topped off around 8K at the dealership when I change the oil).
mrgold35 is offline
dtms1
1G & 2G MDX Discussion (2001-2013)
09-13-2010 10:00 AM
Street Spirit
Cooking & Dining
08-17-2007 11:41 AM
handydandy
First Generation TSX Discussion (2004-2008)
19
11-06-2006 12:25 AM
torqueaholic
01-28-2003 02:23 PM
Quick Reply: Hard to read OIL on stick
