G-001: Led mdx 2007-2010
Old 10-18-2010, 03:04 PM
  #41
nolonyc's Avatar
Originally Posted by angelmdx
Where did you mount the resistors?
I mounted the ballast for my fogs, the drl modules, and the resistors as high as I could on some metal with some double sided 3M tape and wire ties.
The right side is a lot easier since there is more space to work with.
Old 10-19-2010, 02:05 AM
  #42
angelmdx's Avatar
How hot is the resistor?
Old 10-28-2010, 08:16 PM
  #43
angelmdx's Avatar
Are you happy with the color and brightness?
Old 11-24-2010, 02:20 PM
  #44
7th Gear
jtseltmann's Avatar
Hey all, just reading through this and I am curious...I did the upgrade to the v-leds 9005 bulb for my MDX's DRL bulbs..and did no resistor and no module and the color is fantastic and no warnings? The lights look fantastic...are others seeing issues in 2010's without using modules and resistors? i converted out all the interior lights to LEDs..and it looks great.
Old 11-28-2010, 12:41 PM
  #45
angelmdx's Avatar
pics??
Old 11-28-2010, 01:29 PM
  #46
7th Gear
jtseltmann's Avatar
Sure I can take a pic or two. Pics of lights can be deceiving though by they look great especially with the matching 194 parking lights in the front. Just converted the rest of the ext lights to LEDs. All door lights, interior and trunk lights. I also added running board LED lights on the boards. They are my unique touch. Just dropped in 5k Hids in the fogs this morning. Will post pics this week when I can.
Old 11-28-2010, 02:57 PM
  #47
nolonyc's Avatar
Actually I recently removed the DRL modules and resistors. I did notice a drop in lumens. The DRL modules housing fell apart, shorted, and blew my DRL fuse. If I had to do it again I would silicone the DRL module or put some electrical tape around it housing before installing it. After reviewing the housing I noticed that it was pretty filmy and only had 4 little dabs of silicone on each corner.
Old 11-29-2010, 12:20 PM
  #48
7th Gear
jtseltmann's Avatar
Pics as requested..
Parking Lights only (with DRLs)
Full Lights with new HID fogs
Running board lights:
Old 11-30-2010, 06:57 AM
  #49
db22's Avatar
I replaced 1 bulb with the LED bulb and got the warning message so I wnt back to the incandesant. Should I have done both or am I missing something? (2010 MDX) I figured that I would need the resistors but you said that yours worked without the module or resistors.
Old 11-30-2010, 08:55 AM
  #50
7th Gear
jtseltmann's Avatar
well not sure what you all have but i put the LED's in with no other changes...no message from the car..and perfectly acceptable output from the DRLs...heck they look great. I only wish i got the 5K bulbs instead of 6K...then they would match my parking lights better.
Old 12-02-2010, 12:04 AM
  #51
nolonyc's Avatar
If your using the same bulb we are then yes you need to replace both bulbs. I got the same result when I was installing them a while back.
Old 12-02-2010, 06:38 AM
  #52
db22's Avatar
Thank you - I'll try both bulbs but they are not the same bulb so I'll let you all know how it goes.
Old 12-04-2010, 07:33 AM
  #53
db22's Avatar
I changed both bulbs to the LED and got the message so back to incandesant. I guess I need the resistor?
Old 12-04-2010, 10:37 AM
  #54
angelmdx's Avatar
Just curious...how the DRL led looks when the X is far...I hope somebody can post some photos...ty
Old 12-05-2010, 01:11 PM
  #55
nolonyc's Avatar
I guess your using some other brand of LEDS? The LEDS I used were from V-Leds,
http://www.v-leds.com/Exterior-LED/D...-p8022474.html
Old 12-08-2010, 09:36 AM
  #56
db22's Avatar
Yes my LED's are from a different manufacturer and I guessing that they do not draw enough current for the DRL sensing circuit so the solution would be to waste power through a load resistor.
Thanks for your help.
Old 12-09-2010, 02:32 PM
  #57
SupaCL's Avatar
Hi guys, the LED lights look awesome!
Are the bulbs the same in the 07 MDX? (reverse lights, fog, daytime, and parking lights?)
I've been contemplating the change but I was afraid of melting the housing in some areas...
db22 - where did you get your LED's from?
Old 12-29-2010, 12:08 AM
  #58
Woody33's Avatar
Originally Posted by 2010blackonblack
Both the DRL and Fog replacement were plug n play. Getting to them were tight and had to take a few panels off but it was worth the hour IMO. I replaced both the fogs and DRL w/5k lights. Fogs are a bit less effective b/c fog's should really be in the 3k range for effectiveness but I was going more for looks. They are still bright but not as effective in foggy situations (which are few where we live).
Here are the fogs and DRL's I bought. The fogs are the H11 bulbs and the DRL is the 9005 bulb.
http://www.v-leds.com/Exterior-LED/D...-p8824328.html
I also replaced the footwell, cargo, and license plate lights.
In replacing the license plate lights, did you notice an improvement in the quality/visibility of the back-up camera at night?? I have been contemplating replacing the license plate lights and/or reverse lights to help get better visibility at night with the back up camera. Quality is quite poor and may be due to camera placement and OEM lighting. Thanks!!
Old 01-31-2011, 01:35 AM
  #59
tekkno1gy's Avatar
Hey guys,
Just out of curiosity, can someone tell me the benefits of purchasing led's from V-led.com when they sell them for a fraction of the cost on ebay? Just wondering if the huge price gap is actually worth it? I'm looking to replace the parking light, drl, backup light.
Thanks.
Old 01-31-2011, 05:57 AM
  #60
db22's Avatar
Originally Posted by tekkno1gy
Hey guys,
Thanks.
As seen previously on this thread, I used LED's from superbright LED's and I get the error message. The V-led brand must have more resistance and they negate the message but, as you say, it's a high price to pay. There are numerous types that will illuminate with some a lot brighter than others but the system has to recognise that the bulb exists so an additional 6 ohm resistor with the cheaper bulb may be the way to go.
Old 02-05-2011, 08:02 AM
  #61
tekkno1gy's Avatar
Hey guys,
I'm looking to replace my oem bulbs with led from v-led.com. Can someone tell me which specific leds they went with for the following application? I notice that they sell them in different shapes/size/lighting angles etc. Just want to be sure I'm getting the right one.
- license plate light
- door lights
- bottom of the door lights
- interior lights
I've also been doing a lot of reading and am still determining if I want to go with the led drl's since they're so expensive and on top of that sounds like you need the module, resistor, and maybe a relay harness just to get it to work right? I might just put in a 5000k filament bulb or something "easier."
Thanks!
Old 03-09-2012, 12:49 AM
  #62
Woody33's Avatar
Regarding replacing the license plate bulbs- what's the trick to releasing the black strip in the vicinity Of the back up camera?? I have removed all screws, replaced the driver's side bulb & removed the outer case over the camera. The camera is exposed and the black strip loose everywhere except in the immediate vicinity of the camera. What Kim of clips are holding that in? Is the camera unit connected to the black strip- so when I pull it down the camera will be hanging by a wire?? OR will the black strip come down around the camera, leaving the camera in place? I just don't want to break the camera to put in some cheap, albeit good looking, light bulbs... THANKS!!
Old 04-04-2012, 01:53 PM
  #63
3rd Gear
princeville01's Avatar
hi guys, i just changed my stock DRL to LED with the right bulb size and it looks awesome.. but my porblem is that my car on board computer says, "CHECK DRL SYSTEM". i went to the dealer about what's going on and they said the led i bought is not supported. anyone has this problem? what should i do? i need your help. thanks
this is the bulb i bought:
https://store.ijdmtoy.com/ProductDet...Fog_9005_SKU45
Old 04-17-2014, 11:16 AM
  #64
MRROLO150's Avatar
Nolon - Here are the pic's. They are exactly the same brightness and color (5k). I still don't see why they are trying to sell you another piece....
DRL
FOG
This is what I want ! LED on the DRL & pure white HIDs on the fogs.
Old 04-17-2014, 07:37 PM
  #65
Qwikhas's Avatar
Been running these on both x's over a month and love the look.
Old 04-18-2014, 08:34 AM
  #66
portagepaws's Avatar
Can you provide links or bulbs numbers for each bulb you replaced please? The links in this thread to v-leds.com and other site are all dead now...
Ultimately I want to swap out all interior lights, license plate, fog and DRL for 2009 mdx.
Thank you!
Old 04-18-2014, 11:02 AM
  #67
Qwikhas's Avatar
Thank you!
h11 Fogs - http://www.vleds.com/shop-bulb-numbe...11-1-pair.html
resistors for DRL's = http://www.vleds.com/resistors/drl-f...-res-9005.html
DRL 9005 bulbs - http://www.vleds.com/shop-bulb-numbe...45-1-pair.html
these should be the same for 2010-2013.
15% off coupon code = clublexus
mitchigan
05-29-2019 06:53 AM
navtool.com
Sponsored Sales & Group Buys
87
01-23-2016 01:25 PM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
IIDXholic
3G RLX (2013+)
23
10-19-2015 09:40 PM
chiu0nthls
3G MDX (2014-2020)
09-28-2015 03:46 AM
Quick Reply: G-001: Led mdx 2007-2010
