G-001: Led mdx 2007-2010
I purchased new back up lights, footwell lights, cargo lights, and new DRL from v-leds.com. You have to go to Sylvania.com to figure out what bulbs you need but v-led's has a great product. I have replaced all the non-led bulbs in both my mdx and my tundra. It is a quick simple 5 minute mod that adds to brightness plus it looks cool.
Greetings, no DRL-LED, want a lantern as on my picture for the best design MDX interest not
Both the DRL and Fog replacement were plug n play. Getting to them were tight and had to take a few panels off but it was worth the hour IMO. I replaced both the fogs and DRL w/5k lights. Fogs are a bit less effective b/c fog's should really be in the 3k range for effectiveness but I was going more for looks. They are still bright but not as effective in foggy situations (which are few where we live).
Here are the fogs and DRL's I bought. The fogs are the H11 bulbs and the DRL is the 9005 bulb.
http://www.v-leds.com/Exterior-LED/D...-p8824328.html
http://www.v-leds.com/Exterior-LED/D...-p8022474.html
I also replaced the footwell, cargo, and license plate lights.
Thanks for the response 2010blackonblack. I'm actually looking to put the 5k LEDs just for the DRL. For the fogs I was thinking of going with the V-Led 5K HID kit. I emailed V-Led and a technician wrote back and stated that in order to get the full brightness out of the 5k DRL Led I need to buy the module they are selling to step up the voltage. I kind of figured that since I know the 9005 bulbs are running at like 50% their potential. Can you tell the difference between the brightness on your DRL which are not getting full voltage and the fog leds? I didn't think about the foot well lights I might have to get some leds for that. Thanks again.
NoLo
NoLo
NoLo
NoLo
Yea they do look the same. Damn I already put in a big order on some LEDs/HIDs with two of those DRL modules. I'll check the voltage on the DRL plugs without the module and see if it's needed before installing the module. I'm definitely going to take some pics. I appreciate all your help.
NoLo
NoLo
DRL LEDs Pics
This is his Pilot with one of each (non module left and module right).
This is my MDX with stock DRL and the Pilot with the both LEDs and modules.
This is the parking lights stock and Led.
This is my MDX with DRLs leds, the step up modules and the parking light leds.
I decided not to buy the resistors and I am currently getting the DRL message which is not a big deal to me. My friend didn't get the message on his Pilot (lucky bastard) with both modules installed. But without the modules he did get the DRL message. Are you getting the DRL message without the modules for your MDX with DRLs? Also I didn't take pictures of the 5k HIDs since I'm still waiting for them to arrive.
Thanks again for the help.
NoLo
Hey black on black, I finally got and installed the 28 Leds DRL bulbs and DRL module from v-leds. Since the MDX has a tight fit I decided to play with my friend's 2011 Honda Pilot. I installed the bulbs in place of his DRLs. I left one side without the module and one side with the module. You can't really see it in the pictures but in person you can definitely tell the difference in brightness. I was able to see the individual leds on the side without the module. The side that had the module was too bright to look at.
NoLo
NoLo
Do you need the module for the fog lights too?
On another note, to experience I will remove the DRL modules in the process of installing the HIDs on the fogs to see if my DRL message with go away. I just got the inspection done on my MDX with the DRL error message. In NY a DRL error message will not prevent your car from passing, according to the guy that did my inspection.
[quote=nolonyc;12335456] The fog light plugs don't require DRL modules since they already receive the full voltage. quote]
That's where I'm confused then b/c my fogs and DRL match color / brightness exactly and supposedly the DRL aren't getting full voltage but the fogs are. Either way, I'm leaving my set up alone. It works and looks good.
I went with the DDMtuning.com HID kit for my tundra and have been very pleased with it.
Here are the footwell lights I used. http://www.v-leds.com/Interior-LED/D...61206-1-2.html There is only 1 per package so you'll need to order 2. Crawl into the footwell on both sides and you'll see the clear plastic housing...pop the cover off, pull bulb, replace with LED, reattach. These festoon bulbs are polarity sensitive so if it doesn't work when you first put it in, turn them around.
NoLo
NoLo
If your going to order from v-leds try the discount code XENON. I got 15% off yesterday.
NoLo
2016 Acura TLX
i think the op is looking for blacked out taillights. any tint shop should be able to do that
Hey Angel, I ordered the 9005 28 LED bulbs and the DRL Modules and got the error message. I just ordered some in-line resistors from v-leds. I'm going to try the resistor/drl module combo and see if it clears it.
NoLo
NoLo
I have the factory socket going into the resistor, the resistor going into the DRL module, and the DRL module into the LED. Everything seems to be working right for now.
I'm asking because I noticed that V-leds is coming up with a "kit" for Honda/Acura vehicles (available for pre-order), but it sounds like you pieced it together with the generic 9005 modules and some inline resistors. Not sure if the new kit is different from what you used, or just packaged together. Another distinction between the pilot/MDX and most other honda vehicles is they have a dedicated DRL bulb... most other hondas use the high beam at reduced wattage. Again, not sure if the kit is for those type of vehicles or what!?
Thanks!
Hi. Did you use this exact combination to get the brighter output/no error message on your friend's Pilot as well? Or did it work without the resistors? (just modules, no error code)
Thanks!
Thanks!
Yes your right the only reason I did this mod was because the MDX has dedicated DRLs. I wouldn't be able to tell you how to make a DRL message go away on a DRL/Hi Beam system.
I just got the v-leds 9005 resistors installed. Back when I installed it on my friend's 2011 Pilot I did the LEDs and the DRL modules only. He was curious as to how it would look on his Pilot so I did it just to try it out. As soon as I took off one or both of the modules his DRL error message came up. If you look at the pictures I posted above you see a little difference in brightness. It's noticeable after a couple of seconds of the LEDs being on.
My final concern would be visibility in daylight, but with 28 SMTs at full power with the modules, I'm sure it's fine. thoughts?
