Front vs Rear Cylinder Head Oil Staining
Does any body know why the front cylinder head look so dark with oil stain comparing to the rear cylinder head after you remove the cover and look inside. Is it because the front head is getting hotter than the rear? How do you prevent the front cylinder head from getting heavy oil stain?
Latent car nut
Received 2,005 Likes
Disclaimer; I've never broken open the top of a J-Series motor. That said, I have broken open the top end of many V type engines over the years; it seems as often as not, one head is more coated with dark varnish than the other. Another observation is on engines which have used almost exclusively synthetic oil, the difference in color is far less apparent.
Why does this happen? My theories:
There may be a few other causes, however, in the end, varnish in and of itself, doesn't typically cause an issue for many hundreds of thousands of miles.
- On some engines, the oiling to one head is more plentiful than the others; hence the oil in/on the head with the lower amount of flow gets hotter.
- On some engines, the coolant flows first to one head then to the other; one head is hotter than the other.
- On some engines, the coolant comes from a different source or location in the block for each head; one head is hotter than the other.
thanks for the long and insight info. And do you know why Honda place the PCV valve on the front valve cover and run a PVC hose from the other side of the front valve cover to the manifold?
Latent car nut
Thinking about this a bit further, there will typically be a breather tube of fresh filtered air on the valve cover opposite the PCV valve; that may well be another reason why one head becomes more varnished that the other; the side with the fresh air will typically be a bit cooler than the side used to collect the blow-by gases.
On my engine J37A series, the fresh air tube is connected to the rear valve cover. So the vacuum in the manifold is sucking the flow-by oil vapor away from the front cylinder head through the PCV tube, which is connected between the manifold and the front valve cover? What happen if you disconnect this PCV tube and plug the hole on the manifold and let the flow-by oil vapor escape into the atmosphere through the other end of the tube ? I am thinking not to let this flow-by entering back into the manifold.
Latent car nut
If you simply disconnect the PCV, there will be no vacuum to aid CVS, and your engine will suffer the consequences.
Basically, more pollution, a lot more. Then there is the issue of a non-vacuum assisted CVS (Crankcase Ventilation System) which generally result in high water and fuel dilution of the oil, excess sludge formation in the engine, and accelerated engine wear. Back in the bad old days, an open CVS system would use a tube mounted in a high, and relatively oil free location (say the top of a valve cover with a baffle, and then the tube would run down under the car into the under-car airflow. As the vehicle would move down the road, a small vacuum would be formed (much like how wind helps pull smoke up a chimney) which aided the evacuation of the blow-by gases and helped fresh air to enter the engine on the breather side.
horseshoez (03-21-2018)
Latent car nut
A properly designed catch can shouldn't restrict the flow to any significant degree. Are you having an oil blow by issue which is mucking up your intake manifold?
Latent car nut
no. Not really. About 4 months ago I installed oil catcher and about two months later I have small oil leak from the oil pump gasket ( not the seal around the oil pump). So I am wondering maybe the oil catcher caused a buildup pressure and create the leak. So I removed the oil catcher but it’s still leaking. But now I fixed the oil leak by retighten the idler pulley bolt while I was doing the timing belt by accident. I want to reinstall the oil catcher but worry that it may cause the oil pump leak again. The oil catcher trapped significant amount of oil. One thing I noticed was the tube i used seemed to collapse when it was getting too hot. Sorry for the long story.
Latent car nut
I'm thinking the tube may not be the issue, the Catch Can is causing too much restriction between the PCV and the manifold. A more robust tube may be worth a try, but I'm concerned about the can itself.
Latent car nut
ill answer this here bc apparently my answer on the other forum wasn't good enough? the rear bank is the fresh air inlet side of the pcv system, meaning all the fresh air enters this side and draws the vapor AWAY from the rear bank, concurrently the front bank with the pcv valve is under vacuum from the attachment to the manifold. these two forces create a flow from the rear bank to the front bank. this means ALL of the oil vapor passes through the front bank under vacuum conditions (anytime other than WOT basically) which causes staining over time compared to the clean filtered air which gets drawn in through the intake tube at the rear bank.
Thank you. Sir! Now that makes so much sense. Do you think installing the oil catch can will have any benefit or may have the potential of restricting a vacuum line between the manifold and front cylinder head?
Latent car nut
I guess before any of us can answer your question, another question needs to be asked; what are your goals?
Latent car nut
So, why the lower amount of buildup with synthetic oil? One word, "volatility". Conventional oil, even the very best conventional in the world (whatever that happens to be), has a much higher NOACK value than the lowest quality synthetic oil (the lower the value the better). Long story short, as with virtually all liquids, when oil gets hot it tends to evaporate, the hotter it is, the faster it evaporates; a huge percentage of the deposits in the intake system are those from evaporated oil mixed with combustion blow-by gases. In engines lubricated with synthetic oil, the relative lack of oil fog in the stream coming out of the PCV system means a much higher percentage of those blow-by gases make their way into the combustion chamber and are summarily dealt with when the intake mixture burns.
I know lots of folks are concerned about keeping the internals of their engines as pristine as possible, hence the fact catch cans are even on the market, but in the grand scheme of things, it is doubtful a catch can will add even a single mile of life to an engine or prevent even a single item of maintenance from being required.
berettashooter25
2G CL Problems & Fixes
06-20-2011 02:48 PM
