Error codes - AcuraZine - Acura Enthusiast Community
Notices
Error codes
Old 12-24-2018, 09:44 AM
Registered Member
Error codes
My check engine light has been coming on occassionally ( 03 MDX ) I clean the gas cap o-ring and make sure cap is tight and light goes off. Lately, this is not working. Went to Autozone and had them read the codes. They came up with P0420, catalyst system efficiency below threshold B1, and P0455 evap system ( very ) large leak detected. twice.
Is this a major concern?
mlrailguy is offline
Old 12-30-2018, 08:53 AM
Registered Member
Are you required to pass emissions testing?
Have you noticed that you are adding more oil more often, between oil changes?
Has your gas mpg gone down?
The ecu is being told by the O2 sensors that the expected "values" being read, by the O2 sensors, are incorrect.
Then the ecu makes the air/fuel mix more lean, by adding (up to 20%) more gasoline.
Eventually your catalytic converter will become clogged. One day, when trying to accelerate on to a highway on-ramp, you'll lose power no matter how hard you press the gas pedal.
Carpayment4life is offline
The Following User Says Thank You to Carpayment4life For This Useful Post:
mlrailguy (12-30-2018)
Old 12-30-2018, 09:24 AM
Registered Member
Haven't noticed these symptoms yet. Thanks, will get this taken care of soon as possible. No emission testing here, but I like to stay on top of maintenance.
Nicknackzz13
Third Generation TL (2004-2008)
08-03-2018 12:04 PM
woowoo
05-23-2011 11:03 PM
synth19
Second Generation RL (2005-2012)
02-06-2011 11:49 AM
RKeatF1
Second Generation CL Discussion (2000-2003)
11-20-2007 07:56 AM
Chauncey
Second Generation TL (1999-2003)
05-31-2005 08:58 PM
Quick Reply: Error codes
