Erratic RPM's
Erratic RPM's
2007 MDX with about 145K miles. My wife has been driving on the highway and she said a few times the RPM's have been going up to 5000 while doing 70-75 mph (usually 2000-2500). She said the engine sounded normal and no codes are present. Has only happened a few times in the last few weeks.
Anyone else seen this?
Thanks,
Thanks,
Not having any messages or codes is not helping. I was thinking maybe the transmission pressure switches but doing some searches it looks like they throw a code.
Null and proud of it
No engine rev, according to wife, could tach be acting up on it's own, seems unlikely...
Tell her to drive a littke fast, or drive it yourself... Try all different combinations of throttle/gear to see if problem can be replicated...
I will probably try 3 x 3 trans oil change and try to get as much fresh fluid in the system to see if this helps.
maybe she bumped into Manual mode accidently by knocking the gear shift over? Replacing pressure switches is also a good idea along with the 3x3. Be sure to check the color of the fluid too! If the radiator fails, coolant and ATF can mix spelling disaster for the trans!!!
broly
06-14-2017 01:13 PM
crazychris
1G CL Problems & Fixes
05-19-2006 04:49 PM
