Drive belt touching @ tensioner?
Old 07-14-2018, 09:16 PM
MDX07_1's Avatar
Hello guys,
I have a 3.7 and thought id post here because engine setups are similar and someone might catch the problem faster here.
My belt started making a crazy squeak from belt rubbing so I towed car. Today, I replaced the tensioner pulley assemlby but the belt still touches right between the idler and tensioner pulley. Any idea whats causing this?
Please see pictures.
Old 07-14-2018, 09:33 PM
MDX07_1's Avatar
Just to clarify
New belt + new tensioner.
I did not try using the old belt.
Old 07-14-2018, 11:18 PM
AMTMJ's Avatar
The belt appears to be routed properly, so I would say there’s a good chance you have the wrong belt installed for your vehicle model.
Old 07-16-2018, 12:12 AM
Received 8,582 Likes on 6,629 Posts
Where did you get the belt?
Also get that oil leak checked out
Old 07-16-2018, 06:02 AM
frankjnjr's Avatar
IMO: Idler pulley (Spacer-Washer) looks way ODD, to me. I have never seen, a spacer-washer, seated, in that position. I would remove the belt, idler, and spacer-washers, and compare them, to insure a correct match. The belt, appears to be riding TRUE, on the inside idler, but riding too far ( IN ) on the outside idler.
Old 07-16-2018, 07:08 AM
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
*ensure
Old 07-16-2018, 08:04 AM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
The belt on idler sit too close inside, did you replace the tensioner and belt using OEM? when I replace both of my TL I have about 1/4" clearance between them.
Old 07-16-2018, 04:41 PM
MDX07_1's Avatar
Purchased tensioner and belt brand new from Acura dealership.
Before applying the new tensioner, I put just the new belt on, and the same problem occurred, so I went and bought the tensioner and installed it. The same exact issue is occurring. I thought they gave me the wrong belt but I just went back to confirm and they ensure I have the right one.
Still clueless as to what it could be.
I will try removing the idler washer and resetting i in position, but seeing how the same problem occured with the old tensioner and new belt, i'm finding it hard to believe the tensioner is the issue
Old 07-16-2018, 11:32 PM
What was the part number on the belt you bought? Do you still have the old belt?
Old 07-17-2018, 08:24 AM
MDX07_1's Avatar
the part number is
56992 rv0 a05
theyre saying it supercedes the old part #s
Old 07-17-2018, 09:22 AM
Turbonut's Avatar
38920-RCA-A03
Check outside length 47.382".
56992 rv0 a05 2017 Honda Odyssey
MDX07_1 (07-17-2018)
Old 07-17-2018, 10:24 AM
MDX07_1's Avatar
I went to acura and gave them the 38920 part #, they showed me on the screen that its in "MEMO" status which they said means has been updated to the new part which I received.
Old 07-17-2018, 10:35 AM
truonghthe's Avatar
Someone is lying out the A, according to Delray Acura there is no such thing as superseded part# as you provided.
07 MDX PS Belt, Item #12
Old 07-17-2018, 10:39 AM
MDX07_1's Avatar
I just called a Honda dealership and was told the same thing, the part I received supercedes the old part #s. I even had them look up the old part # to confirm
Old 07-17-2018, 10:43 AM
MDX07_1's Avatar
(56992-RV0-A03) as you linked to -- Honda dealership says they have (56992-RV0-A05) in stock, same diameter and rib pattern but possibly different manufacturer.
Old 07-17-2018, 10:51 AM
truonghthe's Avatar
if you insist, there are two #12 listing with two different part number even its the same part. In your case it either they selling you the wrong belt or possible the wrong tensioner assembly, I bought from Delray and Pedoria for years now and never got a problem with fitting. I would recommend you giving those guy a call.
Old 07-17-2018, 02:05 PM
Turbonut's Avatar
Measure the belt o/s.I did check and that number does supersede 4 old numbers and is supposed to fit the '03-'13 MDX.
What year is the MDX?
Old 07-17-2018, 02:16 PM
Well first of all, what year is your car? One can only assume from your screen name it's a 2007 MDX.
https://www.oemacuraparts.com/auto-p...er=56992rv0a03
Also 56992-x Is the POWER STEERING Belt.. not the Compressor/Alternator aka DRIVE BELT
Old 07-17-2018, 04:36 PM
truonghthe's Avatar
^^^ J32,J35 and J37 use only 1 belt to drive the A/C compressor, Ps pump and Alternator.
Old 07-17-2018, 05:32 PM
Carpayment4life's Avatar
The belt (56992 rv0 a05) that you bought is the wrong belt. It fits a 2017 Odyssey.
It's too long and the tensioner is being allowed to position itself near its extreme limit, without much load.
Compressor belt # 38920-RCA-A03 is the only belt under the hood, which is exposed, on a 2007 MDX
If you go to acurapartshq dot com and enter the 38920-RCA-A03 number, then scroll down, you'll see that this belt fits:
03-13 MDX
05-12 RL
04-07 TL
10-12 ZDX
If you go to hondapartshq dot com and enter the above number, then scroll down, you'll see that this belt fits:
06-12 Accord Coupe
06-07 Accord Sedan
07-10 Odyssey
07-08 Pilot
07-11 Ridgeline
NOTE..... the price difference, for ordering it from Acura vs ordering form Honda is greater by $1.99
Old 07-17-2018, 05:40 PM
MDX07_1's Avatar
My other thread got moved into MDX section so sorry about the double posts guys... if someone can lock one thread it may be easier.
Current update
38920 rca a03
56992 rv0 a01
56992 rv0 a03
Are all the same belts but All dealerships are telling me that (56992 rv0 a05) is the NEWEST part that Acura/Honda sell... and this is after calling multiple Honda and Acura dealerships.
My only option at the moment is to order (38920 rca a03) like a few members here stated and try it.
(56992 rv0 a05) is too THICK vs the one I took off, causing the rubbing. If I apply the old one back, there is no rubbing in the same location.
Old 07-17-2018, 06:06 PM
The above mentioned 56992-rv0-a01 and a03 will fit all of the same previously mentioned cars, except the 2017 Odyssey. The 2017 Odyssey is the xxxxx-xxx-a05
Old 07-18-2018, 09:00 AM
MDX07_1's Avatar
oreilly belt it is..
Old 07-18-2018, 09:40 AM
97'CL2.2's Avatar
How many ppl do you need to hear it from Man...buy the other belt. Job finished.
Old 07-23-2018, 09:51 PM
DagMDX2011's Avatar
That's idler looks odd as well with the Belt riding over the edge. It should be right in the middle the flat part, not over the rounded edge. If the correct idler, then it seems installed too far in.
Old 07-25-2018, 03:11 PM
MDX07_1's Avatar
New belt fits.
Smoke coming from crank pulley so readjusted and turned on. No smoke, but rattling from crank pulley and when AC kicks on, loud whine occurs.
Old 07-25-2018, 06:24 PM
97'CL2.2's Avatar
so the parts dept led you astray? WEIRD lol....do all the pulleys rotate freely?
Old 07-25-2018, 08:07 PM
MDX07_1's Avatar
Its a global update. They wouldn't know any better.
All pulleys rotate except the crank by hand.
Old 07-25-2018, 09:36 PM
97'CL2.2's Avatar
Sounds like you need to take a video
Old 07-30-2018, 12:36 PM
MDX07_1's Avatar
https://drive.google.com/open?id=1qm...yuu7oyYscSVKmC
Old 07-31-2018, 09:32 AM
97'CL2.2's Avatar
Remove the belt and run the car, it will tell you if the belt is screeching or the crank pulley is the problem. No screech would be belt problem, continued screech would be crank pulley problem
Old 07-31-2018, 01:25 PM
MDX07_1's Avatar
didnt realize you could run it without belt with risking damaging something
Old 07-31-2018, 03:32 PM
97'CL2.2's Avatar
You can, just not for very long as the battery will not be charging, just run it don’t drive it. You will prob get some codes but those can be cleared afterward
Old 08-22-2018, 05:46 PM
MDX07_1's Avatar
Seems to be the AC clutch. Large screech/heavy load on belt when I turn ac on. without AC, car turns over with an initial 1-2 second screech and then idles normally. If i turn the wheel all the way left or right, the screeching returns if its just on without the AC.
https://drive.google.com/open?id=1gZ...CvnBCkR4lWyUAZ
Old 08-22-2018, 06:00 PM
MDX07_1's Avatar
Heres video of power steering screeching when turning the wheel from the top..
It looks like the power steering is causing extra load when 100% fully turned. It doesn't make noise until reaching 95-100% full turn left or right.
Old 08-22-2018, 06:17 PM
MDX07_1's Avatar
https://drive.google.com/open?id=17r...TpvrN3vk5yXuqF
Old 08-22-2018, 07:28 PM
97'CL2.2's Avatar
seems the belt is slipping around one of the pulleys only under high load rather than spinning freely as it should any time the rpms dip. time to find out which one. could be excess drag on that pulley. try to zero in on the problem pulley with a mechanics stethoscope. maybe warmer than the others if you let it screech for awhile then shut it down.
T Ho
03-30-2012 09:58 PM
acurakings
03-27-2011 11:25 PM
gsclifton
1G TSX Problems & Fixes
03-11-2011 10:30 AM
rxtwo83
07-22-2009 01:34 PM
mrsteve
12-15-2004 09:25 AM
Quick Reply: Drive belt touching @ tensioner?
