Notices
Check SH-AWD System along with Engine light.
Old 01-20-2019, 10:25 PM
Registered Member
Liked 0 Times in 0 Posts
2009 Acura MDX Question I got this along with engine light. When i checked the code it said P0303. I bought sparkplugs and a coil pack. Code mean misfire in Cylinder 3. Cleared the code for a day and a half then it came back this Morning. What else could it be? Please help!
Preach2k is offline
Old 01-21-2019, 10:23 PM
Skirmich's Avatar
Liked 974 Times in 842 Posts
SH-AWD will ALWAYS disable when there is a Fuel/Ignition code up.. So do not worry about it.
As per the P0303 I think you need to diagnose all the coil plugs then if everything seems ok you can start to check out: Valve Lash Clearance, EGR Solenoid.
Skirmich is offline
G&V
1G RDX Problems & Fixes
19
01-05-2019 09:59 AM
errrolgreeene
04-23-2018 10:09 AM
wmahmud
4G TL Problems & Fixes
41
01-03-2017 11:12 AM
Midnight Mystery
First Generation RDX (2007-2012)
03-22-2016 12:16 AM
zoope
Second Generation RL (2005-2012)
08-07-2011 02:20 AM
Quick Reply: Check SH-AWD System along with Engine light.
