Can't figure it out
Can't figure it out
2001 Acura MDX shifts hard in reverse no matter what- just sent off for rebuilt trans, got it back from trans shop, installed and still shifts hard only when 1st put in gear( reverse or drive) not on an incline, thought it might be engine and trans mounts so replaced them all at once hoping that was issue but still no change- while driving trans shifts fine, only when put into gear from drive to reverse or vice versa- any ideas? T.I.A
Did you replace with OEM mounts or ones with vacuum lines? Also did you replace the rear one?
Welcome to the forums.
This thread has been moved from the 3G TL Problems & Fixes Forum to the forum applicable to your car.
sockr1
03-02-2024 03:56 PM
