A/C temp on drivers side warm, passenger side cold
00TL-P3.2 (08-01-2017)
2006 NBP TL MT6/ 02TL-S
I've got an 08 MDX Tech. It was doing that when we first got it-blowing cool on the passenger side & warm (but not hot) on the driver's side. It was simply low on Freon. Now if yours is actually blowing HOT air on driver's side, then blend door.
Forum Contributor
Received 1,391 Likes
Your issue is most likely due to a low refrigerant charge.
See the following article on page 1 of the July 2012 Acura Service News:
Left Dashboard Side Vent Is Warmer Than Right With A/C On
https://acurazine.com/forums/third-g...8/#post8398357
I have cold air coming out of the driver's side vents and hot air out of the passenger side. Both sides set at 85 (for testing). I'm guessing it's this blend door, you are mentioning. Are they easy to repair/replace? Thanks in Advance.
TL-Syndicate23
08-14-2017 12:10 PM
