Any trick to remove camshaft oil seal?
I am doing timing belt, water pump, fix oil pump leak, removing oil pan. Lots of work!! What is the trick to remove and install camshaft oil seal
Might I ask.. Why are you changing these? are they leaking?
Because if they arent, you might wanna reconsider.... Those seals are not usual replaceable items, more like. Replace when they leak and that is very rare.
With those seals the phrase "If aint broke...." fits like a glove, specially the Rear and Front Main Seals.
winkyyy
09-11-2015 04:40 PM
victus1
07-04-2012 07:42 AM
victus1
06-04-2012 05:29 PM
