Brake Pedal Hard
Brake Pedal Hard
2007 MDX - Brake pedal hard to push, feels like loss of power assist.
Feels somewhat normal if pushed when cruising but becomes hard when coming to a stop.
I read something about vacuum, any suggestion on what to look for before going to a mechanic?
Thank you.
Thank you.
first check the brake fluid level under the hood, under the windshield area in the brake fluid container. It should be between Max and Min and it should be a clearish tan color. Any orange or green is sign of moisture/rust in the system and the fluid needs to be replaced.
Mooneyn666gs
3G MDX (2014-2020)
08-28-2018 01:47 AM
chasingthecool
12-05-2015 10:57 AM
