2012 Acura MDX left rear camber
Old 06-17-2017, 05:42 PM
3rd Gear
rjkuba's Avatar
Got new tires and had alignment done. Initially, left & right front Toe, left camber & Toe were out of spec. Three were brought into spec. Left Rear Camber remained out of spec and became worse.
Initial = -1.27
Final = -1.33
Spec min = -1.25 max = 0.25
Should I be concerned?
I was told by PEPboys that changing others caused this one to be out and there's nothing they could do without some type of suspension (eg spring) replacement. Is this bull?
Old 06-18-2017, 05:37 AM
Carpayment4life's Avatar
SPC 67570 rear camber adjuster sold both individually and in pairs, for $75 to $80 each.
Did you look at your old tires, for inner wear and was it excessive?
Old 06-20-2017, 10:04 PM
3rd Gear
rjkuba's Avatar
Nope, but didn't really notice anything before they were removed
Old 06-21-2017, 06:28 AM
Received 16,260 Likes on 11,971 Posts
out of spec TOE will eat tires. as long as your toe is in spec, camber can be out of spec without eating tires.
and looking at the specs, camber is very slightly out of spec. NOTHING to be concerned of! if it were 2 or 3 degrees out, would be a minor concern but can be fixed with a camber kit. with camber being out .5 degrees, it wont drastically change anything
Old 06-21-2017, 07:15 AM
mrgold35
mrgold35's Avatar
Received 1,508 Likes on 1,176 Posts
My rear camber is out on my 11 MDX Adv at -1.3 left rear and -1.4 right rear. I just make sure I rotate and then cross rotate my tires on every oil change to spread out the wear. I still got +50,000 miles on my Conti DWS tires. There is a camber kit for the 07-13 MDX; but, it doesn't fit the sport or Adv models with magnetic suspensions.
LINK: SPC 09+ Honda Pilot 07+ Acura MDX Rear Camber Arm Kit - Import Auto Performance
Old 06-21-2017, 10:03 PM
3rd Gear
rjkuba's Avatar
Smile thanks - great to hear.
Thank you for the info. I feel at ease now
Old 06-22-2017, 06:07 AM
Maybe, I'm misreading your post, however, when I ordered my rear SPC camber kit, I specified my year, make and model.
07 acura mdx sport.
My kit came with a bracket (for each side), which sandwiched between one of the tightening nuts and the main extra large nut.
When I converted to non ads, I left the bracket(s) and when I accepted Acura's extended ads warranty, the bracket(s) remained on the adjuster(s).
I agree that the OP doesn't need to buy the kit, but they are available.
Old 06-22-2017, 08:29 AM
mrgold35
mrgold35's Avatar
07 acura mdx sport.
I'm never 100% sure if these kits will work or not with magnetic suspension. I've been looking since 2014 and some web sites only gave a thumbs up for non-ADS suspension and zero information with ADS MDXs for the exact same part? I just gave up looking and rotated my tires more.
EE4Life
3G MDX (2014-2020)
04-01-2024 09:53 AM
EE4Life
3G MDX (2014-2020)
04-01-2024 09:53 AM
csmeance
1/2G MDX (2001-2013)
63
10-06-2018 05:13 PM
RYAN97812
06-08-2017 11:02 AM
mike0mike
15
10-10-2016 05:21 PM
Quick Reply: 2012 Acura MDX left rear camber
