2011 MDX transission fluid change cost (servivce A123)
Time for Service A123
3 is transmission fluid change.
Dealer wants $260 for it. that seems high?
Express Tire Change will do it for $59.
Suggestions?
Suggestions?
mrgold35
I've been doing 1X drain and refill at the dealership for $100 every 30K for all three of my Acuras (06 TSX 152K, 08 RDX 159K, 11 MDX 123K). You should only do a drain and refill either 1X or 3X with Honda ATF only. No flush or suction process for 100% ATF replacement with Honda/Acura transmissions. I would take my own Honda ATF if the Express Tire Change will use it.
The quote I got was $225 for transmission fluid change and $70 for the transfer fluid. I'm at about 30,200 miles and had them check it at around 27K and it looked fine at that time
shinyknight
08-10-2013 05:19 PM
