2011 MDX - How to Hardwire dashcam?
Old 11-15-2017, 03:15 PM
technocrat's Avatar
Question 2011 MDX - How to Hardwire dashcam?
I searched but couldn't find any thread on MDX and didnt want to refer to threads from other vehicles. Please advice on following
- Which Fuse in the driver side fuse box can be used?
- Information on any fuse kit that you know or have used in MDX for same.
Old 11-15-2017, 04:41 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
You can use the +12V lead out of the auto dimming rear view mirror.. Is pretty easy, I hardwired a GoPro charger that I use for dashcam from time to time.
technocrat (11-20-2017)
Old 11-17-2017, 09:06 AM
technocrat's Avatar
I think that's already used by the Remote starter as that's where they have placed the antenna.
Old 11-17-2017, 09:01 PM
dzionny_dzionassi's Avatar
What kind connection on your camera? if it is USB then it uses 5v not 12v
Old 11-20-2017, 02:39 PM
technocrat's Avatar
Its a micro USB, so a 5v, right? Which Fuse # in fuse box can i use?
Old 11-22-2017, 09:38 PM
Yes, you will need converter from 12v to 5v. I will check on fuse tomorrow.
technocrat (11-23-2017)
Old 11-22-2017, 10:01 PM
Skirmich's Avatar
Most of the car electric system runs 12V that is why I recommended the USB Charger (Car charger) as it works on 12v and steps down to 5V USB nominal. That is how my GoPRO is mounted but if its already used by the OP remote starter I dunno how much amperage it can take after that...
Old 11-23-2017, 04:27 PM
technocrat's Avatar
I rechecked its a mini USB
I am looking at this install kit which has the converter.
Amazon Amazon
See the Fusebox layout below, I see 23 & 33 not in use but no Amperage on them
Which other existing can I use? Also need to check where can I attach ground wire
Old 11-23-2017, 04:56 PM
Skirmich's Avatar
Use #9 Acc Socket or #3 Moonroof
Those are ON when the car is in Ignition and have a good amperage rating, But wont charge once the car is turned off.
If you want a constant voltage so it charges with the car off?
I believe #13 and #16 are always powered regardless of key position and they have excellent amperage rating.
technocrat (11-24-2017)
Old 11-23-2017, 10:40 PM
https://www.amazon.com/Spy-Tec-Hardw...ct_top?ie=UTF8
Attachment 92670
I used #32. camera turns on with turn of the key and it will not drain your battery when you are away from your vehicle.
Skirmich suggested to use moon roof slot, it will work to but i wanted to keep my camera on when ignition off and listening to music etc.
The kit you found on amazon should work with no problems.
Good luck
Old 11-24-2017, 01:37 AM
technocrat's Avatar
Thanks, my dashcam is capacitor based but I prefer something with ignition, so will probably use #3
Good luck
Thanks, Could you please let me know where did you put Ground wire?
Old 11-27-2017, 11:45 AM
technocrat's Avatar
Hello, please advice on where can I ground the black wire
Old 11-27-2017, 04:54 PM
Skirmich's Avatar
Look for a wire loom chassis wire.. The entire chassis is a big ground for EVERYTHING.
Old 11-27-2017, 05:05 PM
technocrat's Avatar
Thanks but am confused now, I thought i would look for a screw/bolt where I can attach the ground cable. What do you mean by Wire Loom Chasis wire?
Old 11-27-2017, 06:09 PM
Skirmich's Avatar
Yeah my bad.. Wire harness chassis ground..
Looks like a bolt that ties seceral grounds tigether, there are many below the dashboard. Example:
technocrat (11-27-2017)
Old 11-27-2017, 10:13 PM
technocrat's Avatar
Thanks, will hunt for one this weekend
