Notices
2009 MDX Tech Package radio wiring diagram
Old 09-14-2014, 04:38 PM
New Member
Hi everyone, I'm new here and I did a search and couldn't find anything. I'm looking for a radio wiring diagram for my 2009 MDX tech package. I want to install two amps and a sub. Thanks!
sirrjiggz is offline
Old 09-15-2014, 01:34 PM
Registered Member
FactoryMDX's Avatar
Get yourself a manual. automanualsource.com
Stereo Wire Diag.pdf
FactoryMDX is offline
Old 05-03-2019, 03:06 PM
New Member
2009 MDX Audio Circuit
Here's the wiring diagram for base and navi trims. You'll need this to bypass or turn on the factory amplifier or make a harness that connects to the oem A and B connectors at the head unit for aftermarket radios, as there isn't a plug and play wiring harness specific to 2nd gen mdxs. I'm waiting on an OEM wired sub harness with both connectors and pinned wires to integrate with a Merta 70 1772 adapter and Pioneer head unit to turn on the amp and utilize the factory speakers and subwoofer without splicing wires. I've got the connector views and numbered pin functions as well which is what I used to translate the wire colors to the aftermarket harness.
The initial install using just the Merta harness resulted in no sound as it only connected to the factory primary wires found in connector A (input). This prompted me to obtain the service manual on ChiltonDIY.com (month subscription is $16). I had some spare wired jumper pins and stuck them directly into the corresponding factory A and B connector terminals and Merta harnes just to try and turn on the amp and speakers. This resulted in sound only in the front and rear door speakers and subwoofer (wired for 4 channel) with humming and static most likely due to the temporary 4 channel connections at the factory aduio unit connectors.
We'll see what happens with the custom harness and steering wheel control interface are used. Otherwise, I'm going to bypass then system altogether.
File Type: pdf
Kyle Bernhardt is offline
Evil Teo
3G MDX Discussion (2014+)
03-19-2016 03:44 AM
not nice
Second Generation RL (2005-2012)
09-05-2015 02:41 PM
Quick Reply: 2009 MDX Tech Package radio wiring diagram
