2009 Acura MDX Tech - Rear Right Door
Registered Member
Hi
I have a 2009 MDX with ~ 80K on it.
I noticed a weird issue going on with the rear right passenger door. When the door is open, the central panel (that displays open doors/tail gate) doesn't show that the rear right door is open. Also, I am able to centrally lock the car even though the rear right door is open.
Any advice on what might be causing this ?
Appreciate your help in advance
Raj
Raj
the sensor is stuck closed
The Following User Says Thank You to thoiboi For This Useful Post:
yuvasethu (02-04-2019)
Open the door, look for the sensor plunger, it's a little black rubber-covered switch. See if it's just stuck in and if you can use your finger to 'unstick' it. Then report back
Registered Member
thoiboi , thank you for the direction. I checked the sensor plunger and could not find any switch covered by the plunger. When I squeezed the plunger, it was just going in & out free like a feeding bottle nipple. (apologize for this reference, as I couldn't find any better appropriate comparison).
I am attaching the picture herewith as well, for your reference. Please advice what I can do to fix this. I am sure if I go to the dealer, it will cost me a fortune.
Rear Right Door Sensor Plunger
https://www.oemacuraparts.com/oem-pa...ta-35400s5a013
Could be just a bad switch, part number is there, Amazon link is slightly more expensive but includes shipping:
https://smile.amazon.com/Genuine-Hon...ustomerReviews
Video here:
Video here:
yuvasethu (02-19-2019)
Registered Member
Video here: https://www.youtube.com/watch?v=Hobu18SceaI
Let me try this out and update you. May take a few days, thoiboi.
Registered Member
hello thoiboi
At last, I received the replacement part last week and had the exercise done. The part was broken and was way deep inside the body. Oh god, it was a hassle to pull the cord out and remove the broken piece and put on the new one. Took almost an hour with very limited tools.
Anyways, I thank you a lot for the timely responses and directions.
Not to overwhelm you, since this past week, I have been getting the below three messages ;
1. Vehicle Stability Assist: 67
2. Trailer Stability Assist: 69
3. All-Wheel Drive: 77
The All-Wheel Drive alert is very transparent as I can clearly see that no power being transmitted to the rear wheels.
Any idea what is causing this?
Yuvaraj
Yuvaraj
Typically a bunch of codes popping up at the same time can be attributed to a bad battery / low voltage.
In your case however, it may be an ABS /Wheel sensor that is malfunctioning that is causing all 3 of those codes to come up at once.
Is the battery old? If it's been a few years, you can try replacing it and seeing if the codes clear after replacement.
Registered Member
MDXAF
1G & 2G MDX Discussion (2001-2013)
09-08-2018 01:40 AM
J&M_MDX
08-20-2018 10:05 PM
mverma
3G MDX Discussion (2014+)
06-23-2015 10:22 PM
kc1953
Fourth Generation TL (2009-2014)
14
06-17-2009 10:42 PM
