2007 MDX Stereo Illumination Wire - Double DIN Installation
Great Northerner
Note: Please move this post if necessary; it's been awhile since I've been here and I'm not sure where to post such things anymore. I used to know where to post when I had my TL Type-S but with the MDX forum I get lost even though there always seems less to talk about (much to my chagrin).
At hand: aftermarket installation of a double-DIN head unit in my 2007 MDX. Talk about a custom job.
I'm nearing completion of installing my new 7" touchscreen JVC head unit in my MDX. I'm about 75% complete. My (current) problem (there are always problems with custom work) is this: where can I find a wire to attach the JVC illumination (orange/white) wire to some wire in the vehicle harness? The older MDX's were SO much easier!!
My theory is this: when the headlights are turned on the dash lights dim, so somewhere there has to be a wire of appropriate gauge I can tap into. I want to remind that I am not looking to tap into the dimmer switch. These wires are around 22 gauge wire.
I'm looking for a wire that may come right out of the steering stock perhaps? The headlight stock, does that have any specific wires that are relevant? What is producing this voltage drop when the lights are turned on so the dash lights become "dim"? Is it a relay or a fuse somewhere connection somewhere in the engine bay perhaps? Everything in the cabin is exposed so I can test nearly any wire within reason.
FWIW I've taken pictures of the whole process, some with my Nikon D7100 so I can get great depth of field shots on objects I really want to emphasize and others with my iPhone, which although still good, trades off quality for ease of accessibility when wanting to take pictures in a small and difficult location. When this project is complete I will explain in detail how it is I went about thsi process, the reason I chose the location for my head unit (where the old nav unit screen was), parts, which wires are what (except for illumination!), costs, and tools required. And patience. A lot of it. I've learned a lot from this project of what to and what not to do so it should be a huge help to someone who is looking for a 4/5 to 5/5 difficulty level project (if you want it to look good and maintain the OEM look in the console area).
Once complete I'll have to ask one of the moderators to help me put some sort of post together or perhaps upload a MS Word file for others to take the plunge if they so desire.
My next project (after finishing my MAME arcade) is to do this all over again but putting the double-DIN where the existing CD changer is, just below the HVAC controls. This setup would be ideal.
Lastly, reaching over to the touch screen is not nearly as bad as one would think. I had many reservations because of this but after much "ergonomic testing" from different people they concluded it works quite well. The added remote makes it that much easier, and it has Blue Tooth to boot.
Thanks in advance, but I wanted to provide an update of this project along with a sincere question about the illumination wire. Up until 06' I believe it was blk/red but that may have been for the dimmer, idk.
Great Northerner
You are correct with the aftermarket head unit. I anticipate that will be hooked up this weekend. I need to do a little more wiring to get the sub RCA's, reverse light lead, and the video RCA wire for the reverse camera (I have disconnected the OEM camera in favor of an aftermarket camera which has "guidelines" as well as infrared.
It's a difficult project but I think it can be easier for the next person now that they know what to do if they choose to go this path with the aftermarket head unit up where the OEM navi was.
My next project will be creating a custom fascia for the double DIN unit right where the CD's are inserted. I am going to ditch the OEM fascia altogether, as well as the gray plastic. I will be using burl walnut most likely (or whatever fake plastic wood which is in the whole vehicle now; I have to do my research).
Registered Member
Thanked 0 Times
in
wow, i can't wait to see the final product. i don't know if this will help but i have all the wiring diagrams/pinouts courtesy of tim from the other forum for the radio harness. pm me your email so i can send it if you want. or if you are a member there i can post the link.
Great Northerner
Wow, that would be a huge help! It would help me with the final wiring this weekend for sure. I would be much more assured with this. I'll send you a PM. Thanks!
Great Northerner
I do have a few updates. I've successfully routed all of the wiring. All I need to do is plug it into the head unit and see if things are working properly.
Unfortunately, the wiring diagrams you gave me were for up to 06' model years. It was an honest attempt though and I do appreciate it! The 2007 through 2013 models (probably 2014 too) are an entirely different beast. There are no Metra connector kits for speakers or adapter kits for single or double DIN. Everything is custom. And I really do mean everything.
Hopefully my attachment of the picture works of my modified console to fit the double DIN. I've used everything from a screwdriver to a MIG welder to get to this point!
New Member
Thanked 0 Times
in
Pinout information for 2010 MDX
New Member
Thanked 0 Times
in
Have you completed the installation on your 2010 base MDX?
This is what I used to get an aftermarket head unit installed
- Metra 95-7820B Dash kit
- Metra 70-1722 Radio Wiring harness
- (This is used only for Constant 12V (Yellow wire), 12V (Red wire), Ground (Black wire). All other wires were wrong
- Metra 40-HD10 - Antenna kit
- 3 sets of RCA to speaker wires
- This is used to connect the pre-amp out to the connector below to connect to the factory amp.
- Metra 70-1731 Radio Wiring harness, this comes with two connectors (got a version of this on ebay, same as one from crutchfield)
- This is the 32 pin
connector next to the 17 pin connector. - This is the connector going to the factory amp.
- All the wires are not correct
- Pulled all the wires from both connectors, be gentle as you will need all the wires
- Connect the 12V (red), Constant 12V (yellow), and Ground (black) from the aftermarket headunit to the 17 PIN connector.
- Connect the Power Amp wire to the second connector
- There are sometimes two blue wires, one is for power antenna (may only have power when listening to radio), use the constant one instead.
- In the photo below, on the top row, the 7th wire from the left, is where I connected the blue wire from the radio (AMP trigger wire)
- After the AMP trigger is done, the wires to the right and the pre amp inputs
- Positive on top, Negative below and slightly to the left
- The order I did them in is
- Left Front (White, White w/black stripe)
- Right Front (Gray, Gray w/black stripe)
- Left Rear (Green, Green w/black stripe)
- Right Rear (Purple, Purple w/black stripe)
- Sub woofer
- Center speaker
- Most aftermarket units will not have this
- If you do not plug something in here, there will be a constant buzz, so I used one of the sub woofer output, but it is probably not correct in the long term
- With this setup, I am able to install an aftermarket radio without cutting any of the factory wires and able to put back the factory radio at any time.
- What is not currently working
- Dimming wire. Have not been able to find it
- Steering wheel control. There is an after market adapter for this. Have not had the time to install it
- Also great to have, is the rear camera feed
- Sub woofer
- Center speaker
New Member
Thanked 0 Times
in
Mdx Stereo wiring
- Sub woofer
- Center speaker
New Member
Thanked 0 Times
in
Soul_Deamon
11-13-2018 05:44 PM
cycdaniel
05-22-2016 07:50 PM
handsom-hustla
11-13-2015 06:04 PM
EE4Life
Fifth Generation TLX (2015+)
09-11-2015 11:13 PM
siularbar
1G & 2G MDX Discussion (2001-2013)
09-11-2015 11:40 AM
