Notices
2007 acura mdx issues
Old 05-16-2018, 06:30 AM
New Member
Good morning Guys
Am new here I wanted to register for a while but I never had a issue with her until now. My issues are that in the cluster I got the aw-hd vsa and abs light on as well of the check engine code. So far when I put the scanner shows that is the check engine issue is the o2 sensor simple issue but wont throw any other codes referring the abs vsa or all wheel drive one please can someone help me on that or show me the way for it. Also I replace the engine mount the front one and now I have to replace the power torque engine mount another words the top right engine mount but can someone show me the steps to get that one out please
thank you guys
mushroomhead1281 is offline
Old 05-16-2018, 07:23 AM
Received 14,052 Likes on 10,445 Posts
how is your car's battery. often times, a bad battery will throw bogus codes..
how is your tire pressure? and brake fluid? often times the sensors on those parts will throw ABS and VSA codes.
justnspace is offline
Old 05-16-2018, 07:41 AM
New Member
I will check them today and keep u posted thank you the fluis are good but inhave to check the battery
Old 08-23-2018, 06:08 PM
New Member
I need some help on this one - we have an 07 MDX Tech - recently battery would drain for no apparent reason, we had alternator checked and changed battery just in case. Today car was fine, kids drove to store turned off and when they got back in all the lights started flashing, VBS lights came on. They turned it off and then battery was dead; after it was jumped the reverse in car is jerky and it hesitates and sounds like it locking up.
knips is offline
Old 05-21-2019, 07:17 PM
New Member
I just bought an 07 acura mdx with a bad engine. so i bought an 09 engine and did an engine swap, changed out the fuel injectors to the 07. The car won't start. It acts like it wants to, but doesn't. Before the engine swap, it would just click. any suggestions, someone suggested that it might be the computer?
calisol84 is offline
Old 05-23-2019, 01:18 AM
Registered Member
To the new members...Don't hi-Jack someone else's thread...Start your own.
Carpayment4life is offline
S L I C K
09-25-2006 08:59 PM
S L I C K
Third Generation TL (2004-2008)
14
06-16-2006 04:02 AM
S L I C K
06-15-2006 07:22 PM
S L I C K
06-15-2006 07:22 PM
Quick Reply: 2007 acura mdx issues
