Go Back  AcuraZine - Acura Enthusiast Community > Acura MDX Community > 1G & 2G MDX Discussion (2001-2013)
Reload this Page >
03 mdx stalls when in gear only at stop ok when driving or in park or neutral
Notices
Old 04-05-2019, 04:03 PM
New Member
Hi Iím new to this message board
my 03 mdx stalls or die when I come to stop
only works fine while driving or in park or neutral
its almost like torque converter clutch do not want to release
it feels almost like you would use both pedals gas and brake at the same time
itís just like like if you would have manual transmission and stop the car without Applying a clutch and will just kill the engine
it also gets worse when transmission gets warmer
itís little bit better after cold start and itís not pulling so hard
i know already that my transmission donít have tc clutch solenoid
i also want to mention that I had my transmission rebuild and only did 3000 miles but it was sitting for so long that the warranty is over
hoping someone can help
i think these pictures shows my transmission
Andrzej Hajdukiewicz is offline
Old 04-06-2019, 06:57 PM
csmeance's Avatar
Received 1,033 Likes on 722 Posts
it may be a bad sprag clutch (one way clutch) inside the trans
csmeance is offline
Old 04-06-2019, 11:15 PM
New Member
so it sounds like changing any solenoids wonít help
if I have take transmission out itís just too big of a job
the sub frame must come out too
i donít have a garage to do it
i think I have take a loss and sell it as is
LipJones
07-19-2018 08:54 PM
fellglenn
10-19-2013 10:25 AM
macfahad
08-06-2013 12:15 AM
Timbeaux38
09-30-2010 03:05 PM
sundevil_CL
Second Generation CL Discussion (2000-2003)
06-23-2007 01:36 AM
Quick Reply: 03 mdx stalls when in gear only at stop ok when driving or in park or neutral
