03 mdx stalls when in gear only at stop ok when driving or in park or neutral
Hi I’m new to this message board
my 03 mdx stalls or die when I come to stop only works fine while driving or in park or neutral its almost like torque converter clutch do not want to release it feels almost like you would use both pedals gas and brake at the same time it’s just like like if you would have manual transmission and stop the car without Applying a clutch and will just kill the engine it also gets worse when transmission gets warmer it’s little bit better after cold start and it’s not pulling so hard i know already that my transmission don’t have tc clutch solenoid i also want to mention that I had my transmission rebuild and only did 3000 miles but it was sitting for so long that the warranty is over hoping someone can help i think these pictures shows my transmission https://cimg7.ibsrv.net/gimg/acurazi...8622e6be5c.png https://cimg8.ibsrv.net/gimg/acurazi...d71c2db074.png https://cimg9.ibsrv.net/gimg/acurazi...c716a00c7b.png |
it may be a bad sprag clutch (one way clutch) inside the trans
Originally Posted by csmeance
(Post 16408213)
so it sounds like changing any solenoids won’t help if I have take transmission out it’s just too big of a job the sub frame must come out too i don’t have a garage to do it i think I have take a loss and sell it as is |
