what do you think is causing this problem?
Old Jan 7, 2011 | 04:32 PM
Kyin01's Avatar
i have a 2003 mdx and it only happens when the car is cold or in cold weather.
When I turn it on, it would make a rough choking noise (like the sound you here when you turn the ignition when the car is already on) but then it quickly goes away and I'm left with high pitch humming / squealing noise that eventually fades away.
What weird is sometimes when I move the gear from Park to Drive, the rpm drops and the engine dies and I just have to it turn it on again.
Any ideas?
this only happens when its cold / in the morning after overnight
Old Jan 8, 2011 | 01:09 PM
mitchigan's Avatar
I'd check your throttle body because it might be dirty. Then check the PS for that whine. Could also be a bad torque converter.
Old Jan 10, 2011 | 11:40 AM
AgentHubcap's Avatar
Does it sound like belt whine? Try spraying some wd40 on the belts in front. If it goes away, then you should replace the accessory belt and pulley.
SidhuSaaB
May 30, 2020 12:40 AM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
