Transfer case fluid change
Has anyone here changed their transfer fluid? I just picked some up at the Honda dealer (Honda gear oil) ... it takes 1 liter.... I checked the drain and fill bolts out while doing the trans. fluid change....seems pretty straight forward. The bolts are pretty close to the transmission bolts and have the same recepticle.
Does anyone have any tips or advice on this service? I'm going to do the rear diff. fluid and transfer case fluid this week-end.
Moderator Alumnus
It may be a good idea to do a complete flush. You basically drain the TC, fill her back up, drive for a mile, drain and fill her back up. You'll notice the TC fluid will be a dark color and new fluid is red. I've seen people do this flush 3 to 4 times until the TC fluid comes out almost a clear red. I hear its worth it. Other than that it should be pretty straight forward. Good luck!
Hey NCGB, I think FiftyFive provided you incorrect infomation. You were asking about the TRANSFER CASE fluid change. He responded with a TRANMSISSION fluid change. Gear oil is NOT red, transmission fluid is. I have a 2007 MDX and a 2007 RDX. I'm looking for DIY instructions for the MDX TRANSFER case fluid change.
^ I think the OP is referring to changing the VTM-4 fluid out of the rear differential? If so, you don't really need to flush. Even ATs don't require a flush if you use the Honda/Acura ATF consistently.
I just changed out the VTM-4 fluid in my Wife's pilot and the old fluid came out very clean (red) after 15K miles. The magnetic plug was clear of sludge as well. This was the 3rd VTM fluid change for our Pilot. I think I might extend the change interval to 20k now based on what I saw today.
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
