Torque Converter Replacement, anyone else?
Old May 21, 2016 | 01:33 PM
wrestrepo's Avatar
StayAtHomeDad
I'm wondering if anyone else has experienced the same...
I brought my 2012 MDX to the mechanic to check the power steering system, as it gets really heavy, like unassisted heavy, when parking. I know that I should expect having to put a little more effort, but this is too much. I have also been noticing a whine, so I figure there was no harm in checking.
While there, I said to the service advisor that the car has been experiencing some "surge" in RPMs, that I cannot duplicate, that it typically happens between 2500-3000, while in high gears, and maybe a slight hill. I got a call at the end of the day from the tech to tell me that my torque converter may be damaged and in need of replacement, and that it was most likely the cause for the surge.
This made me think back to when I got the car, and how I always felt that there was something abnormal about the way the car shifted from 1-2; they checked the VIN and I had the updated software for the early torque converter release.
I am at 55K miles, and fortunately have an extended warranty that should take care of this problem. I am wondering if anybody else has experienced something similar.
TLR small engine surge when driving at 2500-3000 rpms, tall gear, slight hill, tech says I need a torque converter replacement.
Old Sep 9, 2016 | 10:44 PM
Si_jeff's Avatar
I think this is the TSB right now where they are changing the tranny fluid and flushing it. Did they change out the torque converter ?
Old Sep 9, 2016 | 10:48 PM
wrestrepo's Avatar
StayAtHomeDad
The whole thing
Old Sep 13, 2016 | 12:19 PM
s2kstephen's Avatar
That's what I'm expecting my dealer to do on '12 when I drop it off. Let us know if that solves the problem.
Old Sep 14, 2016 | 03:05 PM
bnr32jason's Avatar
6th Gear
What did you find out about the loss of power steering while parking issue? I've found the same thing a few times now. Please let me know, thanks!
Old Sep 19, 2016 | 11:41 PM
Si_jeff's Avatar
Although I have not experienced this on my MDX, I have experienced this before on my TSX. It was running low on PS fluid, check your fluid and see if it is on the correct level and use ONLY OEM Honda/Acura PS Fluid.
Old Oct 2, 2016 | 11:26 AM
ECRD's Avatar
Your power steering pump is faulty get it replaced, known issue on 12 MDX.
The 12MDX 1-2 shift is always a little fugazi like it shifts to 2nd way too quickly and I rather it stay in 1st a little longer but its just the way it's designed or tuned.
The RPMS jumping around on part throttle and low RPMS high gear, up a hill can be a possible torque converter starting to go but it needs to be confirmed with a technician at the dealer.
Michael Hinchey
May 10, 2016 12:58 PM
05AcuraTLMT
Apr 1, 2016 10:17 PM
kin12345
Mar 17, 2016 07:55 PM
