Starter cut relay
2003 mdx with no crank, no start. I want to check the starter cut relay but it’s located on the backside of the driver’s under dash fuse/relay box. How do you access the back of this box? - it’s bolted to sidewall, but has multiple harness connected front and back so it’s not easy to remove to access the back. Any ideas would be appreciated. Thanks. |
