Staggered wheels
Staggered wheels
Anyone here tried staggered wheels on the 2nd generation MDX 07-09?
I'm not sure if it's advisable since our all wheel drive is primarily 100% front wheel at the start.
Moderator Alumnus
Since I had an Evo before the MDX I frequent the Evo forums a lot and noticed that there is a way to do this safely. As long as the tire heights are the same all the way around it should be ok. You most likely have to mess with a tire calculator and find out what size tires you will need for the front and the backs but it is possible. I've never seen this done on and MDX though.
2003 Acura MDX
actually, i heard this was a bad idea. the 4wd sensor might constantly be noticing something wrong and you can wear out that rear diff very quickly. I could be wrong, but that's just what I heard.
JByron
01-08-2016 09:49 PM
nuldabz
09-03-2015 05:49 PM
