Some questions about Gen 2 ACURA MDX
2009 MDX 300K KM
1 The light on the seat heating button does not light up2 Time display error
Is this problem only solved by purchasing the latest version of the navigation DVD disk?
3 The passenger's glass cannot be raised or lowered, Either through the driver's side button or the passenger's side button, but a click can be heard when the button is pressed.
Bad glass lift actuator?
4 The airbag has an alarm light on sometimes,I noticed that the airbag plug inside the interior trim panel on the back side of the left rear door is not connected to the left side airbag air curtain, but is connected to a resistor, does this indicate a problem with the left side airbag air curtain?
Have to replace a side air curtain?
5 The right rear door can only be locked manually, not remotely or via the button on the driver's door.
Is the lock broken?
6 The steering wheel is sometimes not quite right, and it's left and sometimes right.
Time for a four-wheel alignment?
Any suggestions?
Thank you!
Yes.
AcuraMDX2013
1/2G MDX (2001-2013)
03-04-2023 02:32 PM
