Rear Blower Heater / Cooler Blower 01 MDX
Rookie
Anyone have the rear blower stop working (ie - the rear heat control) stop working? I checked the fuses and they are ok.
Thanks in advance for any advice / suggestions.
how you doing, you might wanna check ur rear transistor its at the side panel under the center console on the driver's side just pull the panel off & you'll see itite the only componet over there with a connector.you might just wanna replace it
asoubliere (07-25-2011)
