Range is only at 279 miles?
Old Jul 12, 2009 | 01:03 AM
05ATL40's Avatar
So i recently purchased a 06 touring. My range is saying only 290miles. Is this correct? I have 2 other friends that have the MDX and there getting over 400 miles! Should i take it back to the dealer for them to check it out?
Old Jul 12, 2009 | 04:38 PM
shooter's Avatar
Acuras Only in
I think you should ... SUV with about 21 gal. fuels will go around 400 miles give or take a bit depending on HWY or local ... let us know what happens
Old Jul 12, 2009 | 04:53 PM
FiftyFive's Avatar
Moderator Alumnus
What kinda mileage are you actually getting?
Old Jul 12, 2009 | 07:52 PM
Hodog16's Avatar
Backs the Pack
Have you changed your driving habits recently? Usually the calculated range is based on your recent gas mileage.
Old Jul 12, 2009 | 11:29 PM
05ATL40's Avatar
Well maybe it was due to the last owner. I recently purchased this vehicle certified used at a Acura dealer. I am quite concerned now about the milage. It says i'm avg. on ly 15mpg. I have it scheduled for repairs this tuesday.
Old Jul 13, 2009 | 07:46 PM
hibeta's Avatar
5th Gear
As another poster asked....what is your actual mileage? Not what the computer says but what you manually calculate? Others have indicated that the computer can be well off the mark for various reasons.
Old Jul 13, 2009 | 08:41 PM
05ATL40's Avatar
My actual miles are about 320 miles. still way off the mark of over 400 miles. I'm fillin up at 20gals using premium.
Old Jul 14, 2009 | 06:17 AM
hibeta's Avatar
5th Gear
That doesn't sound too far off the mark. I'd clock the actual mileage for a tank or two before getting too excited. I'm averaging around 18mpg with a mix of city and highway....all city and it would likely be closer to 16mpg. You do know how to calculate your mpg?
Old Jul 14, 2009 | 03:57 PM
ehello's Avatar
Check the transmission fluid. I flushed(3x3) recently and the MPG was improved a lot.
Old Jul 14, 2009 | 10:18 PM
05ATL40's Avatar
so i just brought the car off in the service department. I told them that i'm only getting roughly about 290 miles to tank. The freaking guy told me its the quality of the gas these days. I laughed at his remarks and said you gotta be kidding me right. So well see what they have to say tomorrow. So they gave me 09 TL for a loaner and i looked at the range on it and it says 425 miles. same 3.5L as our MDX.
Old Jul 15, 2009 | 04:25 PM
04yfz's Avatar
You do realize the TL is a much lighter car than the MDX. Mileage has much more to do with other factors than the motor. The MDX has much more rotating mass(heavier wheels/tires), larger overall weight, less aerodynamic, etc. Are you primarly driving it in the city? If so 16 mpg is fairly normal, did you reset the mpg meter since you bought it? Have you checked your tire pressure? Checked/replaced the air filter? Do you take a lot of short trips? All of these things factor into fuel mileage.
Old Jul 15, 2009 | 08:00 PM
TLS101's Avatar
I get 400 miles nearly every tank and once got 24.5 per gallon total Highway....
(keeping within speed limit)
Old Jul 20, 2009 | 10:03 PM
05ATL40's Avatar
Ok so my range has been fixed. Turned out they simply had to reset the trip computer.
Old Jul 28, 2009 | 06:36 PM
akord 97's Avatar
Yup, the mpg meter is an average. The longer you dont reset the trip meter, the longer the average. The range is also based on that. Usually the starting range can vary, but as miles get logged it will adjust.
Old Jul 29, 2009 | 08:43 PM
hibeta's Avatar
5th Gear
ok...so just for kicks....since resetting the computer has no effect on anything involving your actual gas mileage. (miles per gallon)..then you really did not have a clue what your actual gas mileage (miles per gallon) was and probably still don't?
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
Skirmich
Sep 15, 2015 06:41 PM
PortlandRL
Sep 14, 2015 12:01 PM
Aug 30, 2015 02:39 PM
