P2649
P2649
Hello i have a 08 mdx just got a codes P2649, 77-01, 91, 35, 32
35 32 is for the tps, i had those for a while.
I just got the p2649 and it comes with the vsa and shawd lights. No problem accelerating or running, any ideas you guys can help me with?
Update:
this light came on when i was idling for 10-20 mins at a parking lot. When i try to clear this light it comes right back on. However when i start driving for a bit and then clear it when i stop it will go away and wont come on. I am assuming something is cloughed up and with low oil pressure at idle turns up this light. The wiring to the sensors around the spool looks good.
Update
So i have went on and purchased the filter housing assembly that includes the 2 sensors and replaced it. The problem went away. When i took off the housing the gasket was all over the place and some even broke and went in almost. I could of probably just get the gasket but mind as well replace the whole thing. Problem solved
NBPacuraTL
1/2G MDX (2001-2013)
04-02-2010 08:52 AM
