MDX spring rates stiffness difference between trims
Is there difference in spring rates between MDX trim levels?
Is it common for MDX to have rear end sagging like all Honda odysseys.
I've seen some first generation MDX people using lowering Honda Odyssey 2005-2007 springs made by Bilstein I believe.
I want the stiffest springs Honda makes. Rears I think are all the same in diameter. So should be interchangeable on all suv truck platforms
Sport models have different spring rate than base for 2007-2013 models. Sport should be stiffer and mine have sagged and are awaiting replacement after 14 years.
