LISENSE plate led
Old 09-13-2014 | 01:52 PM
acurabum's Avatar
LISENSE plate led
Hi all
Just bought a MDX 2011 with only 45 kms and very happy with the SUV .
I try to change the Lisense Plate lighting to LED but not sure how to remove the plastic cover around the backup camera ( do not want to break anything ).
I remove all screws and got the left side of the plastic cover off but do not know how to remove the right side .
Please someone help .... or any picture to walk me though the removal .
Thanks guys.
Old 09-15-2014 | 09:17 AM
FactoryMDX's Avatar
I would be able to help you out with this, but I still have no options to attach files...
Is this b/c I'm still in the 15 days?
Old 09-15-2014 | 02:12 PM
FactoryMDX's Avatar
Ok, I'm up and running now... time to burn some rubber.
Once you've removed all the screws that hold the trim piece in place and the one that holds the cam enclosure you should have just enough wiggle room to pull the trim down and see the 2 clips that hold the cam up inside the rear gate.
There should be enough room to squeeze a small flat head screwdriver in and all you have to do it push forward on the clip and pull down easily.. do one then the other the same way..
That should release the camera and then you can pull the trim out and get to the license plate lights. Here are some pics to see what you are dealing with.
These 2 screw mounts act as a screw and a clip for the camera.
Old 09-23-2014 | 10:52 PM
acurabum's Avatar
Thanks Factory ...it works like a charm ...just swap my lighting to Led and very happy with it .
Thanks again ,
Old 09-24-2014 | 08:56 AM
FactoryMDX's Avatar
You're welcome brother.. Glad it worked out for you.
gatrhumpy
19
12-31-2015 05:22 PM
blacktsxwagon
10-27-2015 11:12 PM
DementiaPhuro
09-29-2015 06:31 PM
Ratheruneeq
09-28-2015 08:41 AM
eastcoastguy
09-23-2015 07:29 AM
Quick Reply: LISENSE plate led
